There are a few things I'm not real clear on. Maybe the experts here can help me understand.
1. The Darlington Diff Drop Brackets and the Ball Joint Flip mod both reduce the CV shaft angles after doing a torsion bar lift. Which is the better method, and why?
2. Would there be any benefit to doing BOTH?
3. How else can the front suspension be lifted beyond the 2" - 3" cranking the torsion bars will get you?
4. What would be needed to modify the suspension to fit 35" tires?
