Looking for some advice and help in brain storming a solution to my rear camera. Hope someone can help me.
Okay, I have the Pioneer AVIC-N1 navigation system and compatable with this install I also put in the Pioneer wide angle rear view video color camera. I did the install my self. Here's the rub.
The system works perfect but the little pocket that the rear view camera fits in makes for a tight fit and due to space requirements angles the camera pointed down. This is great when backing up cause thats where you want it to point so you can see how close you are to whatever but its worthless to see much more than 10 feet behind your behindor to monitor your backside if your towing something. So here is my idea.... I thought maybe a trip to a wrecking yard to scrounge up a power remote rear view mirror and maybe Rube Goldberg the camera in some fashion by removing the mirror and somehow attaching the camera. Im pretty much convinced that that little camera box will have to be cut up a bit to allow the camera to pan up... Then reinstalling the camera and motor assembly sans the mirror. I don't know if Im getting my point across or if its just a lame idea...I respect your thoughts folks on the matter or for even a better suggestion. There appears to be a little extra room behind the spare tire but I don't have a clue as to how much space these remote mirror servo motors use up or even if there in the door or behind the mirror housing... Any thoughts on the matter ladies and gents??
