Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: Where to buy 456 gears??
    May 2004
    Used to own #777
    If it will take the 4.56 third member from another Isuzu, it will take the locker (RD44) too. I have moved my 4.77s from an 89 Trooper to an 88 Trooper to a 94 Trooper - all the 26 spline axle. Those 3rd members will accept the RD44. Now, the VX cast iron housing may have some interference problems with the locker, but that wouldn't prevent you from swapping to 4.56 gears and an earlier 3rd member at the same time (2 birds, one stone).
    -Tad
    Dragon Bob has an ARB in the front. Search for old postings. He may have given all of the details.
    Roy
    1999,White,Iron Man,1429
    Roy
    I think my front ARB was in before Bob's. I was asking about the rear. In fact I wired mine for the rear when it became available or when the LSD failed to lock up.
    I already take it where I shouldn’t.
    Todd
    Feb 2003
    only thing different about our rear axles is that we have a thicker ring gear. I put in a 3rd member from a 1994 Pup and it works and fit...so ARB RD44 should fit and work in the rear axle.....
    Jul 2004
    2000, Kaiser Silver, 0196
    Don't want to side-track this thread too much but as long as you're talking lockers I've got a quick question. How much difference would a rear locker make if we've already got limited slip? The left:right torque split with a locker is always 50:50 - i.e., if one tire has no traction the other is still getting half the torque right? So what is the torque split with a LSD if one tire has no traction?
    Apr 2003
    1999 Astral Silver 1222
    In my opinion, LSD and especially our sturdy rear LSD has on and offroad advantage until you get a tire in the air, or alot of weight difference from side to side (without using the e-brake trick). Lockers will lose traction at the same time. Bad on Ice, snow, gravel, and wet roads. Yikes! An LSD will corner better especially while driving spiritedly on or offroad- especially rally. A locker has the ability to turn both tires the same speed no matter what. even with 2 tires, lockers F & R will go.
    I had a spare rear third member from an Amigo or early Trooper. Swordy just put it into his VX. If that worked, any older 12-bolt should work in any VX. It is just the newer Troopers, 98+, that have the different 12-bolt.
    BTW - That third had the 4.55 gears.
    Steve G
  1. Banging gears again!!! What now!
    By jasonm621 in forum VX Troubleshooting...
    Last Post: 05/19/2014, 08:28 AM
  2. GEARS, GEARS & MORE GEARS
    Last Post: 06/04/2010, 09:03 AM
  3. 4.77 Gears
    By kpaske in forum VX Modifications...
    Last Post: 04/04/2010, 06:24 PM
  4. New Gears
    By WiSDoM in forum VX Modifications...
    Last Post: 02/14/2009, 08:36 PM
  5. 4.88 gears?
    Last Post: 02/21/2005, 11:26 AM
