Results 1 to 13 of 13
Thread: EGR Valve Cleaning
    '99 Ebony VX #0038
    EGR Valve Cleaning
    In case anyone is interested, I noticed there wasn't a good EGR Valve cleaning HOW TO out there, so I made one and posted it to my web site. There also wasn't an illustrated Fuel Filter replacement HOW TO (though there were a few good non-illustrated ones), so I made that one too. If anyone cares to take a look, and offer any suggestions if I left out anything important, I'd be happy to update them.
    EGR Valve Cleaning HOW TO
    Fuel Filter Replacement HOW TO
    Nicely done -thanks!
    2001, Proton Yellow, #0580
    Most Excellent.
    -- John
    May 2003
    '99 Astral #1613
    Thanks!
    2001 Ebony 0177
    Wonderful!!
    NC 1999, ironman, 0358
    Great job and thanks...What are the symptoms that the ERG is in need of cleaning? Bad idling, acceleration, an error code perhaps?
    Western North Carolina...
    Veni, Vidi, Velcro
    Feb 2004
    99 White Ironman
    It's people like you that make this forum so valuable. Thanks for the work!!!
    2001, Proton Yellow, Vehicross, #0170
    BTT
    I'm with dkmiller68. What are the signs of failure?
    '99 Ebony VX #0038
    If it gets clogged enough it will set off an error code / check engine light and can cause rough idling. Some have even claimed that it can cause engine failure, but that is questionable.
    If the nut becomes loose, it will cause a diesel exhaust or clicking sound from underneath the hood.
    After giving mine a thorough cleaning I felt as though my VX ran and idled a bit smoother. The improvement was minor, but worth the 10 minutes it took.
    Thanks for the info, that is a great how-to page.
    Sep 2004
    2000, Ebony, 0786
    Thanks kpaske.
    Also, NAPA sells a replacement gasket with a screen in place for the valve hole (large hole), about $10.00. This helps with breaking up the carbon as it passes through. Helping to keep the carbon from building up in the egr.
    I had this problem with my S-10 SS. It caused the engine to stall at idle and under load on the highway. Got so bad the truck wouldn't run. Took off the egr and cleaned it real good/replaced the gasket with the NAPA one and it has run just fine since.
    Raider
    2000-Ironman 0219
    EGR cleaning
    Nice work on both pieces. I'll be in my garage this weekend. Thanks
    Mar 2010
    2001, foxfire, 2001, 1117
    Dead links. If anyone can repost.
  1. cleaning egr
    By evillecutter in forum VX Troubleshooting...
    Last Post: 12/21/2012, 03:49 PM
  2. where is PCV valve located, and how do i clean the valve tube?
    By CoastieCosta567 in forum General Tips...
    Last Post: 05/14/2007, 09:33 AM
  3. EGR cleaning gone bad :)
    By Dare2Dream in forum VX Troubleshooting...
    Last Post: 10/12/2005, 07:21 PM
  4. cleaning the egr
    By Triple X in forum VX Troubleshooting...
    Last Post: 03/16/2004, 03:35 PM
