Here's a listing of switches for foglights, tailgate release and the "Fuzzy" hole replacement bezel.
The switches are lighted.
The foglight switch has an indicator showing the switch is in use.
The Tailgate release has an indicator light that comes on when the tailgate is ajar.. I'm working on a solution to make it work. It will probably require a second pin switch to be used unless you go without the dome light tie in option.
Fuzzy Hole replacement switch bezel p/n 8-97107-569-0 ($12.26)
Tailgate Release switch (from 95.5-97 Rodeo) p/n 8-97093-960-3 ($41.67)
Foglight switch (from 98-newer Rodeo) p/n 8-97125-279-2 ($18.73)
Block off plates (Switch Blanks) 8-97081-617-1 ($2.04)
I obtained these through St Charles Isuzu But you can get them from any Isuzu parts source.
Edit... Updated....Here is a link to a line drawing showing the terminal patterns for the switches..
Terminal Pattern
Edit......The new way to connect these will afford the internal light to be dimmed.. Surprize to me that Isuzu uses a variable ground to dim the dashlights.
The pin to the pin switch on the Tail Gate release switch is for a second pin switch to control the indicator contained within the switch, showing if the read door is ajar. You can connect it to either door jamb switch but the indicator will light when any door is opened.
