Results 1 to 7 of 7
Thread: Tranny fluid change
    Jan 2004
    '00 Firefox #0308
    Question Tranny fluid change
    Please help! Where is the mystery transmission filler plug located?!? Several people refer to it in their posts, but no description as to location. A pic would be great ... but I will take any assistance I can.
    David
    David
    Jul 2004
    2001, Black, VX, 0930
    The drain plug is on the bottom. The filler plug is on the side towards the top. New fluid has to be put in against gravity. Usually with a pump.
    Nov 2002
    I'm doing two Isuzu trannies (VX & Trooper) today and will have photos up in my site tonight. I'll post the info in this link and the other thread as well.
    Jan 2004
    '00 Firefox #0308
    Thanks Cool, but I will have to wait for the photo from Joe_Black. I see what appears to be two drain plugs. One in the bottom of the pan, and a second on the corner about 21/2 inches higher yet still facing down. Pumping into that I could probably only get 3-4 qts into it. On the side I see the two lines running into the side and that rubber plug held in by a c-clip. I know it will probably help to download Tone's CD manual. I need a more definitive description, ie which side of tranny.
    David
    1999, Ebony Black, VX ,1976
    both plugs are on the pan. lower one drains ,the higher one fills. you cannot change all the tranny fluid by draining it. shawn
    1COOLVX
    Nov 2002
    Lightbulb
    Okay, I'm a day late. Still can't figure frames out! Bleh! In any case, I've got one method of changing tranny fluid up. The "poor man's flush" didn't yield the results I had hoped for on the two trannies I did, but still got about 70% of the fluid out. I'll be doing updated article on this technique as well as other ideas.
    So check the site out and let me know what y'all think: Joe Black's VehiCROSS Site
    Jan 2004
    '00 Firefox #0308
    Psychos - Thanks.
    Joe - Thanks alot. The photos and detail are great. I know how I will be spending my Friday night! I look forward to seeing some of the other projects.
  1. Tranny fluid
    By kehecross in forum VX Talk...
    Last Post: 04/30/2012, 06:31 PM
  2. Replies: 7
    Last Post: 02/24/2007, 09:06 AM
  3. Transmission Fluid Filter Transfer Case Fluid Change
    By driver3 in forum VX Troubleshooting...
    Last Post: 09/16/2005, 02:23 PM
  4. Replies: 5
    Last Post: 01/12/2004, 05:42 PM
  5. Help... Switching from mechanical tranny to fluid tranny???
    By ScubaSteve in forum VX Troubleshooting...
    Last Post: 10/03/2003, 02:41 AM
