View Poll Results: People with Intercetors
Voters
28. You may not vote on this poll
  • Had Tranny replaced
    3 10.71%
  • Clunking Noise
    0 0%
  • Hard shifts
    3 10.71%
  • Other Issues, please Eplain in Post
    3 10.71%
  • No Problems
    19 67.86%
Results 1 to 15 of 22
Thread: Interceptor Kills Transmission - Fact or Fiction
    Interceptor Kills Tranny - Fact or Fiction
    Want to get some feed back from VXers who have interceptors installed as to the negative Impact of the interceptor on the tranny.
    Is there a reason to worry?
    The Bantan's Relm
    Gallery
    Myspace Page
    Feb 2003
    suposedly...
    according to Tone...the interceptor will not damge anything....but....my interceptor shorted out and killed my electro magnetic clutch coil in my T-case...which cancels your TOD ....$1100 in labor and $150 for the part is what Isuzu says to fix. I know it was the Interceptor because I was throwing all sorts of codes from Tranny and T-case...tried every single fix...nothing worked...removed Interceptor it was smoked and smelled burnt.
    I loved the performance of it...but not the part of changing my T-case...luckily it wasn't my Tranny.
    Tone will go ahead and speak up for his product and diss me...but, I am not down talking it...just telling what happened truthfully.
    May 2002
    2000, Proton Yellow, VX, 0584
    To save all the "I have no problems with mine" posts, I made a selection on the poll.
    BTW... I haven't had any problems at all with mine
    Scott / moncha.com
    2001 Proton VX 0790
    I had mine slip down from where it was ziptied, and burnt the harness on the downpipe. the short threw a code for PCM TCU solenoid. I fixed the harness, and have had no other issues.
    John C.
    Thanks Scott! Spazz, no need to dis you. Yours is the only reported damage from the Interceptor but since it is connected to the tranny cabling/connector which is separate and shares no circuit with the TOD/Transfer to my knowledge, I'm not sure how it is possible. If it smoked, please return it for analysis and replacement so we know what happened. I have shipped over 50 of these units with few problems, usually install or setting issues for the most part.
    Feb 2003
    email me your address and I'll ship old one for analizing and/or possible replacement.
    S/c'ed and no probs.
    May 2004
    Used to own #777
    About the only comment that I have is that when in power mode I can feel a kick in the butt on each downshift (when braking to a stop light for example). Accelerating is great though, and there aren't any issues at all in normal mode.
    Mark (wareagle) rode in my VX at Uwharrie and he commented on how fast the shifts were.
    -Tad
    Spazz, your email address is hidden. I will get you a RA number from AutoTrans on Monday and get you the address so you can send it straight to them. I'll let you know what to write on the package and will need you to put a description of the problem in with the product. Thanks.
    Others, if you are getting a hard shift on downshifting, you may want to reduce the pressure a bit.
    2000, Black, VX, 0021
    one problem i have is the trans with interceptor hits redline and cuts out when in power mode and first gear.
    does not feel too good with supercharger. hits really hard. so i just lift a little when it gets close and lets it shift.
    Anthony
    Of course it will hit rev limiter in 1st with Interceptor or without, LOL! If shift is too hard, please decrease pressure on the Interceptor.
    Sorry, i ment to say when taking of in drive and 1-2 shift it hits rev limit. i have to let off the gas when getting close to redline in first so it will shift to second w/o bouncing off rev limit.
    It never did this w/o interceptor
    Thanks for adding that option
    I Just got in from the Club, lots of hotties!!!
    Well, I had my tranny replaced once, after installing this Mod. symtoms were, really hard shifts, clunking and jerks on deceleration, even on low mode.
    I Love the extra kick I get from the Interceptor (feels like I got a Super Charger), but its seems like I got to replace my tranny again. Its been less than six months since the last tranny.
    Does having an interceptor installed void my warrantee?
    Feb 2003
    Isuzu does not honor their warranty after 30,000 miles...they will worm themselves out of covering anything even if you have an after market air cleaner.
    Serious..I get it all the time. they just turn me around or tell me they will charge me for warranty work or tell me that nothing is covered for some odd reason or another. They even told me that the Tcase is NOT part of the Drivetrain....gee with a TOD Tcase that has 2 output shafts hooked to the back of the Tranny and LOCKED all the time hubs...not auto..but LOCKED all the time and no selector switch to disable TOD and you do not have the option of disconnecting the front driveshaft and running it like you could with 2 wheel drive vehicles if something goes wrong.....ummmm YEAH I think that the Tcase IS part of the drivetrain and they are smoking crack laced with Drano
  1. SWAT team kills Marine in his home
    By RabidPony in forum Chit-Chat ...
    Last Post: 05/21/2011, 12:53 AM
  2. Acetone: Fact or Fiction?
    Last Post: 11/06/2008, 08:21 AM
  3. Fun fact of the day- WMS
    By Ascinder in forum VX Modifications...
    Last Post: 11/20/2007, 04:57 AM
  4. cool fact
    Last Post: 08/20/2007, 11:03 AM
  5. interesting fact
    By GOVEHIX in forum VX Talk...
    Last Post: 03/06/2005, 07:30 PM
