Results 1 to 7 of 7
Thread: Suspension thunk - Help!?
    Mar 2004
    1999,white,IronMan,1239
    Question Suspension thunk - Help!?
    I hope someone can share some helpful advice because I don't know where to start.
    My '99 ironman has almost 70k and I replaced the shocks with rancho 9000 series about four months ago. Shortly there after I started hearing a thunk sound when going over harsher bumps from the front passenger side. There is no problem when turning (unless I hit a bump), so I'm not so inclined that it is related to CV joints.
    Any similar experiences, ideas, or recommendations? I'm looking for some advice before I dive into changing CV joints, I haven't had the pleasure of changing CV joints yet.
    Sway bar links?
    1999, Ebony Black, VX ,1976
    i have had to tighten the lower bolts on the front shocks a couple times. i also have the rancho 9000 .the bushing in the front shock seems to be a little big ,and if the bracket is not tight against the lower shock mount it will make a noise.you should be able to check it if you wiggle the shock by hand. shawn
    1COOLVX
    99 white ironman
    hey, got the same exact thing here with the rancho shocks on a 67K VX. This noise is really perticular, only happens on certain bumps and is definately coming from the front end like something is loose.
    May 2004
    No VX anymore. :(
    bump stops maybe?
    Steve
    it is the shocks. i had the same problem as stated above and tightened up the bottom bolt on the front shocks and solved the problem.i had to do this twice . i believe the hole that the bolt goes through is too big. shawn
    Mar 2004
    Thanks guys!!!!!!!!!!!!!
    I can't believe it. I went to go look at the shock, and the bolt had been sheared off!!. The shock was still in place though. I have since replaced the bolt and everything is all good. Thanks for all the posts.
  1. Help needed with a THUNK
    Last Post: 01/09/2015, 05:51 PM
  2. Suspension Question (Bose Suspension)
    Last Post: 12/06/2012, 09:32 PM
  3. suspension
    By s2mad in forum United Kingdom Special Topics
    Last Post: 10/26/2010, 01:26 AM
  4. suspension
    By fishmanstan in forum VX Talk...
    Last Post: 09/20/2004, 09:07 PM
  5. Suspension!
    By diver2k3 in forum VX Troubleshooting...
    Last Post: 02/23/2004, 01:14 PM
