				Originally posted by VXRaNgEr
Pull your manifold cover off
Locate PCV:
Remove hose clamp and simply pull PCV out
Push new PCV in (FV384 for Fram) and re-clamp hose
Remove rubber grommets from posts:
Push grommets back into plastic manifold cover and replace
Done!
				Originally posted by Jolly Roger VX'er
My replacement PCV came from AutoZone and fit perfect.
It was as follows:
DEUTSCH PCV VALVE for a 2000 ISUZU TRUCK VEHICROSS 4WD
Unit Price:   $3.49
Part No.:   PCV193
Weight:   0.05 lbs.
Availability:     Online: Ships within 2 business days
                        Store: Normally Stocked
Since you are experiencing oil usage..you might want to pull the EGR Valve and spray out the valve and tube to clear out any carbon build-up.  It is not known for sure if either of these actions will affect your oil usage.  I can only say my VX did use more oil than normal on one occasion and by changing the PCV it went back to normal usage (about 1/3 quart in 3,000 miles)
