Results 1 to 10 of 10
Thread: Streering feels a little loose....
    Feb 2004
    2001, SUPERCHARGED!
    How do I get it back to early days of tightness? Is it a quick fix?
    Draftsman of the dead
    Nov 2002
    Lightbulb
    You can adjust the steering gear easily enough. If you're not familiar with the procedure I can post directions with pictures as I think I'll be doing Heraclid's this weekend.
    Apr 2003
    1999 Astral Silver 1222
    I think someone did a how to on this a long time ago. if not here, then maybe at the ol' vmag. Either way, if you do it again- thanks. we'll have one here for reference!
    Feb 2004
    2001, SUPERCHARGED!
    Thanks, I would like to see that info....I'm off to hit the search button.
    Feb 2004
    2001, SUPERCHARGED!
    .....and nut'n came up.
    Feb 2004
    2001, SUPERCHARGED!
    Cool thanks, I'll try it tomorrow.
    J
    I must admit, I have never played with the steering box adjustment.
    Tight or loose steering can be a combination of many components: Ball joint, tie rod ends, centerlink, steering idler, steering box.
    On the Amigo which, I believe, shares the same type of steering system as the Trooper/Vehicross, (recirculating ball), many of us have had to changed the steering idler:
    The bushings/bearing get a little worn causing the shaft to have a little play. The old one in the picture is also bend just slightly.
    Larger tires as well as a little bit of play in all of the above listed components can add up to steering that is not quite what it used to be.
    Steve G - 90 Amigo Guy
    Nov 2002
    Unfortunately we didn't do the adjustment this weekend as hoped, but will at the ERS rallycross on the 9th. So photos and procedure will be up shortly after.
    May 2003
    '99 Astral #1613
    Sorry. :-( I really did kinda want to do it before the rally too, for obvious reasons.
  1. Transmission Loose?
    By ipd in forum VX Troubleshooting...
    Last Post: 01/31/2016, 07:44 AM
  2. Transmission feels wierd... Are these symptoms normal?
    Last Post: 09/15/2005, 02:50 PM
  3. Loose Steering
    By Leah in forum VX Troubleshooting...
    Last Post: 09/23/2003, 07:42 AM
  4. a loose EGR tube...?!!!
    By transVXmen in forum VX Modifications...
    Last Post: 09/11/2003, 10:19 PM
  5. How to fix a loose Fang...
    By Navigator in forum VX Talk...
    Last Post: 05/22/2003, 11:49 AM
