Results 1 to 9 of 9
Thread: SHIAT VX is in the shop...
    '99 SC Ebony #1961
    AGAIN!!! Arghhh
    Pulled 4 codes, same as last time... I just got her back not too long ago and it was the Tranny mode switch, TP sensor and some other thing... Man this sucks hope they find out what is worng...
    So weird the CE light comes on and it shifts really HARD and revs weird, then this morning the CE light still on but it runs fine??
    Frustrated,
    -Dave
    Thanked: 7
    Post
    Is this a frayed wires thing?
    Anita
    2000 Ebony #263
    AnitaProtich.com
    '99 SC Ebony #1961
    No clue about the frayed wires thing?? What is this you speak of?? HELP as the mechanic is sorta stumped and is going to go though a schematic of all the component's and electrical things hooked up to the Mode switch...
    Thanked: 7
    Post
    Oh Dave.. not sure if that is what is causing the problems but some of those wiring harnesses in and around the engine bay can start rubbing on surrounding metal and cause all kinds of trouble.. sporadic or continual. My mechanic pointed out a harness in the engine bay that could affect normal idling. I think somewhere in all the threads here, I posted a pic pointing to that potential culprit. I will try to look for it.
    '99 SC Ebony #1961
    Cool, will pass this on to my mechainc... thanks, fingers crossed.
    May 2003
    Originally posted by Anita
    Dont know if this is your problem but I would check CLOSELY the wiring harnesses running through the engine department including the harness that runs below and behind the driver side headlight. Frayed wires grounding out can blow fuses and cause the weirdest power outs including the ones you describe. Some of us have experienced it firsthand.
    Thanked: 7
    The one that Im referring to runs just right of.... shoot...I dont know the name of the parts of the engine. Its to the right of the engine, about halfway back. Wrapped with black tape...
    But yes, several owners including me have had experiences with that particular harness as well.
    If all else fails, you could call my mechanic. He has fielded questions from owners and mechanics around the country. Email me if you want his number.
    '99 SC Ebony #1961
    Dealer just called... He checked everything (wiring harness and all) and the only thing he thinks it could be is I need a new EGR valve and gasket. They apparently share the same wiring that is causing my TP sensor code and Mode Switch codes? But he said that he is taking an educated guess, because the VX is running fine again.... arghhh
    I am hating to spend 300 bucks to replace the valve that might not even solve the problem. He said I can just drive it till the EGR goes if that is even it. Anyone have any suggestions? I gave the ok to go because I need the VX back.
    -Dave
    2000 Dragon Green VX 0485
    Engine clean
    I would be curious to know if persons experiencing intermittent electronic problems wash or clean their engines
    Perhaps trapped moisture in some of the electronic connections under the hood.
    Bob F
  1. Transmission shop: a hat tip
    By twalker920 in forum VX Talk...
    Last Post: 04/06/2012, 10:18 AM
  2. Shop Manual
    By tom4bren in forum General Tips...
    Last Post: 04/19/2011, 09:57 AM
  3. Shop manuals for your PWC
    Last Post: 08/10/2009, 07:10 AM
  4. VX in the shop
    By Scott Harness in forum VX Talk...
    Last Post: 08/14/2007, 05:18 PM
  5. Shop Recommendation?
    By calilu in forum VX Talk...
    Last Post: 03/28/2007, 12:49 PM
