Results 1 to 4 of 4
Thread: Shock Mount Adapter Interest
    Nov 2002
    Question Shock Mount Adapter Interest
    I've finally decided to re-shock with the Bilstein 7100 series shocks and am fabricating brackets to allow for the eye/eye mounting since our stock setup is eye/stem. The only reason I'm fabricating is that I've been unable to find something already out there, so if you know of something please share the info before I hit the machine shop. Otherwise, I know many others here have interest in Bilstein and other brands that are eye/eye. If you'd like a set of brackets chime in now and I'll have additional sets made all at the same time to reduce costs. I'm guestimating at less than $50 a set, depending on material used. 7075-T6 is my current choice with 4041 a close second, just depends if I go machined or formed.
    So post your interest here, it'll be about a week before I put the order in for the brackets.
    2001 Proton VX 0790
    Nov 2002
    A W E S O M E ! Thank you! Thank you! That's what so great about this board and similar on-line communities, the collective knowledge and comraderie just surprises and surpasses!
    Thanks again!
    1999 White Ironman 0769
    Smile
    OK Joe,
    I looked into this way cause the jeep accessory places make these type adapters.
    Now tell me which shock will meet the collapsed measurment. The only one I could come up with thats close, is the Class 11 rear, but it will still bottom out. Not with a lift but then will you have the extended length you will need?
    We need to cut out the top of the shock hanger and weld on shock tabs to be able to use any of these shocks.
    Not to rain on your parade but I've been down this road.
    I hope you have better luck than I, finding some combination that will work!
    BTW The class 9/11 front comes so close it hurts! (stem & eye shock)
    But they're sure fun!
  1. SHOCK ADAPTER from Independent 4X
    Last Post: 05/11/2009, 07:03 PM
  2. Tone's Light Adapter for Trailer Lights
    By ojmagg in forum VX Troubleshooting...
    Last Post: 11/20/2006, 11:03 AM
  3. Sheared rear lower shock mount bolt
    Last Post: 01/27/2006, 03:35 PM
  4. Cassette CD adapter clicks XM radio
    By dkmiller68 in forum VX Troubleshooting...
    Last Post: 05/04/2005, 05:49 PM
  5. SC Throttlebody Adapter
    By Hotsauce in forum VX Modifications...
    Last Post: 08/14/2003, 06:15 PM
