I am to the point that I need to think about getting my driveshaft/propshaft custom cut to fit... I would like to go ahead and have the rear shaft done before I get the VX fired up... I need to have someone or multiple someones make a measurement if possible... If possible, could I get a measurement of the distance from the rear transfer case output to the pinion input of the rear axle? I don't think it has to be a COMPLETELY accurate (to the hundredth of an inch) measurement as the rear driveshaft has a slip joint to compensate for distance or length depending on the suspension travel. In the case that there are several people who do the measurement, keep in mind that my VX has the OME 912 springs on it so I have 1.5"-2" lift in the rear... again, the EXACT accuracy isn't compeltely important... of course, the more accurate the better... but its not rocket-science! lol
I would like to drop my rear driveshaft off to a tranny shop sometime this week for cutting and balancing. This would make it possible for me to actually drive the VX to the shop for the front prop shaft modification...
Anyway, I hope the request is clear enough... any help would be appreciated. Thanks in advance.
					 Of course, I'm not one to complain about cheap favors...
    How much lift you have under your VX?  I think it would be good if I could get multiple measurements... just a though...
