Results 1 to 8 of 8
Thread: Hood no release
    NC 1999, ironman, 0358
    Hood no release
    Sometimes it does and somes times it doesn't. Mostly doesn't on first attempt. It doesn't engage until the lever is almost fully extended. Perhaps the cable is stretched...I couldn't see any adjustment so I installed a spacer (nylon tie wrap pulled max tightness) down at the mechanism at the latch so as to effectivly 'shorten' the cable;but, alas, to no avail. Has anybody else encoutered this? Thanks, Don in Atlanta
    Western North Carolina...
    Veni, Vidi, Velcro
    2000,silver,vehicross,0460
    I'm having this problem right now. The release mechanism isn't releasing. I have a rusted hood latch spring and mechanism that needs to be replaced.
    Feb 2003
    check the position and tightness of bolts on that bar that is vertical extending from the hood release and bumper bar and front plate area.
    If this is out of alignment or if the bolts came loose it could cause exactly what you are experiencing.
    If that doesn't work, then check the hood hinges.
    easy quick cheep methods to try
    Mine has never worked since I bought it.A light thump on the
    hood while pulling the release works, it also pops open by itself
    if I have the "bra" installed.
    Jul 2004
    2000 Black VX 0363
    Ahh, copious amounts of silicon-based lube will help this.
    When I was test driving VX's... EVERY ONE had rusty hood latches. I couldn't believe it. I had mine replaced under warranty because the hood wouldn't open. I'm keeping it coated with a thin layer of oil to keep the rust off.
    2000 Black VX 105k
    1999, Ebony Black, VX ,1976
    i got mine to open by adjusting the rubber adjusters so they push up more on the hood. shawn
    1COOLVX
    Thanks all for the great ideas...will repair this weekend. dkm
    Problem solved YIPEE
    Some times you could get the hood to release by slightly pulling up on it ...it would 'pop' a little. Sometimes you'd have to go back and try again. Turns out, when I was playing with the mechanism (was going to adjust sideways to see what would happen), I noticed that there is a third bolt and mine was missing...lo and behold I found it in laying below and before any adjustment, reinstalled it and it works great. This third bolt was the bottom one that supports the mechanism from below. The top 2 fasten to the painted portion at the top. I suspect that the mechanism was a little crooked in the vertical axis.
  1. Hood Release Lever
    Last Post: 03/28/2008, 04:26 PM
  2. If Bin laden can release videos......
    Last Post: 09/11/2007, 06:56 AM
  3. hood release
    Last Post: 04/10/2006, 04:53 PM
  4. Hood release problem
    By dkmiller68 in forum VX Troubleshooting...
    Last Post: 05/26/2005, 06:36 PM
  5. Help on hatch release mod, plz
    By Fusion in forum VX Troubleshooting...
    Last Post: 09/24/2002, 03:30 AM
