I need some information... My VX is currently binding up a little in corners under acceleration. Only under acceleration, and only in turns around 90 deg. It does not do it if I coast through. There is no sound, just some binding as if the rear limited slip is locking. I have done all of the fluid changes, in fact I just did one back in May, with the additive, and synthetic fluid. I brought it to a transmission/diff. shop that I have used many times before. The told me that it was not the rear diff. and that it seems to be somthing in the TOD that is locking it up. I just wanted some of you to put in your 2 cents and tell me what you think is up. Or to see if any one else has experienced this problem.
