Results 1 to 10 of 10
Thread: Autotrans Interceptor
    2000,silver,vehicross,0460
    Does the Interceptor change the stall speed of the torque converter?
    No only shift firmness and deley of torque converter lockup. We already have a relatively high stall converter. I've spoken with a number of performance shops about redoing our converters and they recommend that unless it has broken or you circle track or drag race a lot, there is little benefit to having it modified or changed.
    And if you look at it from a pure labor standpoint to replace it, you are looking at well over $500 to drop the drive shafts, tod/transfer, and tranny w/ fluid. I have a spare converter if you really want to try it and an account with AutoTrans race division in Canada who I have spoken extensively with.
    Thanks for the answer.
    Looks like my next mods are supercharger and interceptor, but I won't have the $$$ till the summer.
    Feb 2003
    whatever you do, do not lose the little rubber covers for the pot screws....or if it gets wet it will short out your Tranny.
    Mine did that and the intercepptor did not blow it's 10 amp fuse. It just shorted the Tranny and T-case out and itself.
    now, I do not have an interceptor and my Tranny makes weird whining noise and Magnetic clutch coil in T-case went out.
    Uhg! Now you make me wanna take mine off!
    We have VERY salty winters here and that kills plastic and rubber. Starts the good old dry rot process. Last thing I need is for one of the rubber tips to rot and fall out.
    What to do, what to do....
    '01 Ironman
    My rubber pieces fell out the first week after installation! Then my zip tie job came undone and my interceptor fell on my exhaust melting one of the corners and now the line pressure doesn't work, but the delay is still there. Make sure you tie it up there real snug.
    Interceptor will not blow tranny and a 10amp fuse is way to big. A short or failure of the product will leave it in a factory, pass thru mode. Rubber covers can be siliconed in place but I have been running mine for several years without covers and not had any problems.
    Feb 2003
    then,
    why did mine do it????
    Aliens have taken over you VX Spazz but don’t take that the wrong way. You’ve got a few other wiring nitemares if I recall.
    Feb 2003
    nope
    no wiring nightmares.....
    rear side panels had the aft most fasteners come loose.
    In the sun it would cause the panels to relax just enough to make alarm go off and dome light not go off. I replaced fasteners and no more issues.
  1. AutoTrans Interceptor Adjustable Electronic Shift Kit
    By stt9c1 in forum VX Modifications...
    Last Post: 05/05/2011, 05:46 PM
  2. VX Interceptor
    By handeeman in forum VX Talk...
    Last Post: 06/20/2009, 02:44 PM
  3. AUTOTRANS interceptor
    Last Post: 08/23/2006, 06:03 PM
  4. interceptor help
    By technocoy in forum VX Modifications...
    Last Post: 09/05/2003, 01:29 PM
  5. AutoTrans Interceptor Install
    By majork in forum VX Modifications...
    Last Post: 04/27/2003, 01:53 PM
