Results 1 to 4 of 4
Thread: drain plug power steering??
    Dec 2002
    1999,Wht/blk debadged Ironman,#0188
    My workshop manual explains how to drop power steering fluid...has anyone done it? and might you add some insight to the job?
    thanks
    face the mirror
    was this ever answered? searching didnt turn up anything, my power steering fluid looks a little darker than id like.. im guessings its never been changed (im at 42k) so id like to change it out myself... any tips/how tos? or is it just worth takin to the dealer
    Apr 2006
    2007 Suzuki V-Strom 650
    I pulled my return line and quickly put it in an old oil bottle to drain. That got 90% of the fluid. Remove the serpentine belt and turn the pump by hand to get the rest. Doing this, it should be trival to flush the system.
    '99
    A true flush is the way to go, but it can get a little messy. If ya don't even wanna get your hands dirty, ya can try a quick method that does an okay job, but not quite as good as a flush.
    Get a gallon of Dexron III tranny fluid. Take off the reservoir cap and pull straight up on the baffle with pliers to pop it out. Take out all the fluid with a turkey baster thing and refill with fresh fluid. Put on the cap and start up to circulate for a short time. Repeat that four or five times. Put the baffle back in and maybe do it all again a week later. It's real quick and easy. Ya won't get out every drop of the old fluid, but you'll come pretty close and your fluid will look a whole lot better.
    From automedia.com- "Just as with fluid maintenance for your cooling system and transmission, it's not necessary to change all of the power steering system's fluid to keep it in good condition—as long as it's being done before visible deterioration occurs."
    Mark
  1. Rear Differential Drain Plug
    Last Post: 11/16/2014, 10:28 PM
  2. How to drain power steering
    By VXNIT in forum VX Talk...
    Last Post: 10/02/2010, 06:48 PM
  3. Replacing oil drain plug
    By VX KAT in forum VX Talk...
    Last Post: 06/27/2009, 03:12 PM
  4. Radiator drain plug
    Last Post: 03/24/2009, 11:12 PM
  5. Oil Drain Plug Help
    By DeafVX in forum VX Talk...
    Last Post: 08/16/2003, 12:11 PM
