I spent (too many hours) this weekend doing some wiring in the VX. I wired the dash for the tailgate release button, moved the alarm light, wired the driving light switch, wired for the arb compressor switch, and wired the 4wd and TOD switches (including turning off the TOD display and having some 4-hi indicator).
I also mod'd the alarm so that one push of the button opens both doors.
It took hours because I soldered all of the connections, and installed connectors in the new harness so that the dash can still be removed.
Now I just need to install the popper itself and connect it to the new wiring. I also need to find a wire near the alarm module that is connected to the door pin switches so that I can connect the last wire for the popper switch (the wire for the door open indicator).
I have two Isuzu switches installed for the 4wd/TOD mod. The TOD switch turns off the TOD display on the dash when it is in the off position. There is a yellow wire, which is the common wire for the TOD display in the small harness on the back of the cluster. I just switched that with the TOD switches second set of NC contects. The first set goes to the TOD off relay.
http://tad.grosvenor.org/gallery/VXMods/CIMG1018
There is also a light that is unused in the cluster that I installed a bulb in to use as my 4-hi indicator. It's labelled ISP or PSR or something like that. The book didn't describe it and it isn't anything that I remember seeing on an Isuzu before.
Aside from a mixup with the relay (where the factory installed the case with the "key" on it upside down) things went smoothly. I also drilled out the factory radio brackets and mounted the radio to them, instead of inside of a sleeve in the dash. Now I don't have to disconnect the radio if I want to remove the dash again.
-Tad
What if the Hokey Pokey really IS what it's all about?
