sent the oil out to be checked. recieved the report today everything is normal. no abnormal wear and no excesive contaminants. shawn
1COOLVX
What? Sent your oil out?
Draftsman of the dead
you can send a sample to be tested. they check for wear metals (bearing , piston , cylinder,and valve material). they also check for contaminants. these reports can be used to find problems in the engine before you have a major meltdown. shawn
Send where? How much does it cost??
i get it done for free at work. do a search on the web for oil analysis and you will find many places. it is normally around $20 . mine is done by kendall. when i can get it scanned i will post it. shawn
		I once had this done on my Fiero using a kit from K-Mart that cost about $8. That was a couple of years ago...so I don't know if the kit is still available or not.
