After returning from a trip the other day I discovered a strange musty order in my VX and a WET MAT on the passenger side, UH-OH !! I had about 1" of water under the carpet so I remover the seat and sucked all the water out with a carpet cleaner. After reading past posts I found that nobody had found the leak so I set out to fix that! After a couple of hours with a gardenhose and a flashlight I've got it kinda figured out.
Most of the water sprayed here dissapeared into the truck.
The water then pored out from behind this black mat and pooled-up and soaked into everything from the firewall to the back of the front pass. seat.
Water also pools-up under this thing which looks very inportant so make sure to dry the surrounding area.
As of right now I havn't fixed the problem but now we atleast know how the water's getting in. Any suggestins would be helpfull especially if you know the route the water might be taking once it gets inside
