Results 1 to 5 of 5
Thread: shocks for lift?
    '01 Ironman
    shocks for lift?
    OK I am doing a 3.5" lift, 2.5" from OME springs, and 1" poly spring spacers. What is the ideal measurements? From my research I have come to the conclusion of using.....
    Stock front shocks= 15.35"x10.24" and these dimensions do not change, so I would use Bilsein OE performance series- B46-1738 H1?
    Stock rear shocks= 19.25"x12.56" so after adding 3.5" of lift I would use Bilstein 5150 series- BF5-A195-H1 which measure 22.5"x14.17"?
    Please no comments like "run stock shocks" as I want to replace all 4 of them. Thank You!
    Jul 2004
    2000 Black VX 0363
    what are you gonna do with your stockies?
    2000 Black VX 105k
    '01 Ironman
    good question? Not sure how much life is left in them, I really put a beating on these shocks..... jumping, rallycross, hard corners, offroading, for 64,000 miles. Once I get them out I will let them go for real cheap.
    '99 Ironman, 0992
    Be sure your rear brake lines including the center line will take the extra 3.25" of droop and put on the 2" bump-stop extension to avoid bottoming out the extra 2+" of the rears. I haven't measured the shock at full stuff into the wheel wells on the rears but that extra length might be a problem witout the extension.
    1999 White Ironman 0769
    Smile
    AlaskaVX,
    Another opinion I got from a Bilstein dealer that outfits Baha racers was to spend a little more for a much better (and owner rebuildable) shock, the 7100 reservior shock.
    This guy's opinion was that the 5150 was just more marketing hype and looks than substance.
    He agreed that our front shock was a real problem to find a replacement for. He suggested looking into a upper conversion unit that accepts a standard eye to eye shock. A lot of the jeep guys use them.
    Let us know what you end up with.
    But they're sure fun!
  1. To lift or not to lift that is the question
    By CatFish in forum VX Talk...
    Last Post: 03/28/2012, 03:15 PM
  2. Lift thread to end all lift threads
    By tbigity in forum VX Modifications...
    Last Post: 05/22/2007, 10:54 PM
  3. What shocks
    By colmhd in forum VX Troubleshooting...
    Last Post: 11/21/2006, 04:58 AM
  4. VX shocks
    By GOVEHIX in forum VX Talk...
    Last Post: 11/26/2004, 07:02 AM
  5. What shocks for lift?
    By yal^ in forum VX Modifications...
    Last Post: 06/21/2004, 09:22 PM
