Cool new gauge a buddy told me about - gives live readout of codes and their meaning - http://www.scangauge.com/scan.htm
So my check engine light has been on since I bought the car on December 2nd. When I tried to get it inspected in Houston it failed because:
Fault Codes:
P0440: Evaporative Emission Control System Malfunction
P0405: Exhauast Gas Recirculation Sensor A Circuit Low
What does this mean and what should I do? I do have the PV Muffler (it was on there when I bought it). Thanks in advance, Ryan. Oh yeah I drove outside the city to Waller, TX(middle o' no where) to get it inspected and it passed even with my cracked belt that I need to replace!
Did you buy it from an auto dealer? If so, take it back and amke them fix it - in KY it is not legal to sell a car that will not pass the emissions test. If you bought it from an individual (or the place you bought it from will not help), it may be under warranty. I think that emissions systems are covered by law up to 50,000 miles.Originally Posted by LittleBeast
Tone, while I like that box, the one I have my eyes on is www.autotap.com
check it out, you have a laptop or a palm pilot and you have a code reader, and engine diagnostic tool
and yes its going on my carputer![]()
2000 Black VX 105k
There's a TSB issued in April '00 regarding P1171.
Service Information
Condition: Some customers may complain that the engine runs rough or MIL light on. In some cases, vacuum leak noise may be heard as well. [Intermittent rough idle and/or the MIL is on with DTC P0171 (Fuel Trim System Lean Bank 1), P0174 (Fuel Trim System Lean Bank 2), or P1171 (Fuel Trim System Lean During Acceleration)].
Probable Cause: It was found that the inlet manifold gasket(s) were cracking due to excessive stress caused by heat expansion/contraction.
Correction: Replace old inlet manifold gasket(s) with new inlet manifold gasket(s).
Don Viner
Sunset Isuzu
6211 L Street
Omaha, NE 68117
O - (402) 733-2227 ext 214
F - (402) 733-0395
M - (402) 505-2147
don@sunsetisuzu.com
http://www.sunsetmotors.net
