Results 1 to 12 of 12
Thread: P1171 Fuel System Lean During Acceleration
    Jul 2004
    99, Silver, 1044
    Alright, well I fixed my misfire on cylinder # 2. It ended up being the interconnect better the coil on plug and the spark plug. A hole had burned through the rubber and was shorting the coil to the cylinder head.
    I fixed this about 2 weeks ago, but recently I've been having a problem with low power. It had been getting progressively worse, but I haven't been able to figure out the problem. I went and had the car scanned which came up with the following:
    P1171
    P0300
    Engine Misfire Detected
    P0137
    HO2S Circuit Voltage Low Bank 1 Sensor 2
    At this point I'm thinking I have a pluged up fuel injector or something. I can floor it and it doesn't accelerate past ~60mph. Its like it just has no power.
    What do you guys recommend?
    Thanks,
    Justin
    did you reset ecm after coil repair?
    2001 Proton VX 0790
    The lean codes suggest vac leak, either EGR or intake manifold I'd guess.
    John C.
    gone but not forgotten
    An ignition misfire can cause a lean reading too, as the motor is pumping unburned oxygen through the dead cylinder.
    albert
    ________
    GT380
    These codes are misleading.
    02 circuit voltage low
    indicates a volt problem in general or from ecm.
    Lean UNDER ACCELERATION
    could be vac leak or fuel starvation, i.e., fuel filter or pressure regulator
    Misfire
    Could be due to either one of the above conditions or could be an old stored code.
    Reset the ecm if not done already.
    Jul 2004
    99, Silver, 1044
    Well, I took it into the shop. Looks like I had a bad o2 sensor that was causing my A/F mixtures to be off during closed loop.
    Justin
    May 2003
    2001, Kaiser Silver #1213
    same here...
    I had same problem. Lost acceleration on the highway. Started slowing even with the gas pedal floored. When I got over to the shoulder it completely stalled out.
    Check engine light; retrurned P0137, P0157, and P1171.
    They replaced both O2 sensors and its running real smooth now.
    Cool new gauge a buddy told me about - gives live readout of codes and their meaning - http://www.scangauge.com/scan.htm
    2001, Ebony Black, 1153
    Question Questions about my Texas Vehicle Inspection Report
    So my check engine light has been on since I bought the car on December 2nd. When I tried to get it inspected in Houston it failed because:
    Fault Codes:
    P0440: Evaporative Emission Control System Malfunction
    P0405: Exhauast Gas Recirculation Sensor A Circuit Low
    What does this mean and what should I do? I do have the PV Muffler (it was on there when I bought it). Thanks in advance, Ryan. Oh yeah I drove outside the city to Waller, TX(middle o' no where) to get it inspected and it passed even with my cracked belt that I need to replace!
    Jul 2004
    2000 Black VX 0363
    Tone, while I like that box, the one I have my eyes on is www.autotap.com
    check it out, you have a laptop or a palm pilot and you have a code reader, and engine diagnostic tool
    and yes its going on my carputer
    2000 Black VX 105k
    There's a TSB issued in April '00 regarding P1171.
    Service Information
    Condition: Some customers may complain that the engine runs rough or MIL light on. In some cases, vacuum leak noise may be heard as well. [Intermittent rough idle and/or the MIL is on with DTC P0171 (Fuel Trim System Lean Bank 1), P0174 (Fuel Trim System Lean Bank 2), or P1171 (Fuel Trim System Lean During Acceleration)].
    Probable Cause: It was found that the inlet manifold gasket(s) were cracking due to excessive stress caused by heat expansion/contraction.
    Correction: Replace old inlet manifold gasket(s) with new inlet manifold gasket(s).
    Don Viner
    Sunset Isuzu
    6211 L Street
    Omaha, NE 68117
    O - (402) 733-2227 ext 214
    F - (402) 733-0395
    M - (402) 505-2147
    don@sunsetisuzu.com
    http://www.sunsetmotors.net
    2001,Ebony,VehiCROSS,1092
    Quote Originally Posted by LittleBeast
    Fault Codes:
    Did you buy it from an auto dealer? If so, take it back and amke them fix it - in KY it is not legal to sell a car that will not pass the emissions test. If you bought it from an individual (or the place you bought it from will not help), it may be under warranty. I think that emissions systems are covered by law up to 50,000 miles.
  1. Fuel System Issues?
    By vxcp in forum VX Troubleshooting...
    Last Post: 02/02/2013, 09:00 AM
  2. Code P1171
    By snowtrooper1966 in forum VX Troubleshooting...
    Last Post: 04/30/2012, 09:45 PM
  3. learn fuel at acceleration
    By simel in forum VX Troubleshooting...
    Last Post: 06/07/2008, 09:13 AM
  4. Code Reader - Lean System?
    By wekilled in forum VX Talk...
    Last Post: 01/27/2008, 12:46 AM
  5. Something sticking in fuel system
    Last Post: 01/21/2006, 01:41 PM
