Results 1 to 15 of 15
Thread: Drivetrain
    Jul 2004
    2001, Black, VX, 0930
    Unhappy Drivetrain
    Took my 2001 VX in for a front bearing pack 60,000 mi. and also found out that right rear seal was blown Had gear oil all over brake and rotor assembly. Having both sides replaced. 895.00.
    Does this blown seal seem a little premature? Also How do you do a transmission flush and refill? Does the tranny and power steering share the same fill area. is this something that has to be done at the dealer?
    Feb 2003
    duh,
    do a search and you will find the answers.
    no, the power steering does not share the transmission fluid...it IS filled with Dextron III fluid though, as is the T-case and Tranny.
    Same fluid, different fluid reservoirs.
    Tranny has a fill hole on up top and drain hole down bottom. I believe Isuzu wanted $300 from me for servicing the tranny which only included a drain/fill and changing out filter.
    when they power flush they hook up a pressurized machine and use about 3 or 4 extra quarts of fluid to flush out old fluid.
    2000 Dragon Green VX 0485
    Re: Drivetrain
    [WoW both rear seals replaced for $850 that seems to me to be way out of line.
    Complete Transmission flush should be about $80 at specialized shop. Do not go to Jiffy Lube.
    Power steering fluid replacement is separate & you must disconnect line at pump and drain & refill & bleed etc.
    Bob F
    Jul 2004
    850 includes both seals rear brakes(oil soaked) Repack front bearings. sound reasonable?
    That's about 60 bucks in parts and 10 to 12 hours @ labor rate of $80- 100/ hour. They should be able to do it faster than that, as you could probably do it in your driveway in that time.
    1999, Ebony Black, VX ,1976
    i had mine replaced under warranty. i think i had 38,000 miles or less shawn
    1COOLVX
    I had all of those things done FREE under warranty at 70k.. it's part of the 10/120000 powertrain warranty. Are you the second owner, are there limitations to the warranty when the title transfers?
    Jul 2004
    I'am 2nd owner. Warranty does not transfer. I'll do the work myself. You know I'am from S.C. If I need to I can clean or store parts in the bathtub. HAAA!
    Feb 2003
    I'm
    original owner and have 61,000 miles. they said they called Isuzu America and the TOD and the T-case were not covered under the 10 year/120,000 mile warranty. They said I had to have brought it in under the 50,000 mile bumper to bumper
    They're giving you the run around... look at your warranty book, in bold print they have this line "What is covered" and it lists the transmission and everything. I'd have to run out to the car to get the book, but someone here might have it handy. I actually had to get it out to show the isuzu dealer for them to believe me. They were like "man, that's a good warranty"...... Right now i have a slight knock in the steering, if I jiggle the wheel from left to right I can hear a click, so I'm going to have that checked out and the entire steering mechanism is covered as well. This warranty does cover tons of things you wouldn't traditionally think of "powertrain". Now if I can just get them to replace my blistered wheels....
    Feb 2003
    if,
    I would have brought it in with under 50,000 miles, they would have told me it was not covered over 36,000.
    serious, everytime I bring it in and try to get them to honor the warranty, they say all sorts of assinine things such as "Sorry, you have an after market aircleaner and that changes everything, you have moded your truck".
    May 2002
    2000, Proton Yellow, VX, 0584
    James,
    Your dealer is on crack!!
    Scott / moncha.com
    Jul 2004
    2000 Black VX 0363
    http://www.vehicross.info/forums/sho...1897#post41897
    transfer case is covered by powertrain warranty.
    2000 Black VX 105k
    Feb 2003
    I didn't see,
    the T-case on the list...I just saw the Transmission case.
    Jul 2004
    2000 Black VX 0363
    Dude,
    Just do yourself a huge favor, and call the Owner relations hotline.
    800-255-6727
    Hours: 6 am to 5 pm (PST)
    Monday - Friday
    http://www.isuzu.com/company_contact.jsp
  1. Drivetrain vibration
    Last Post: 03/11/2016, 05:19 PM
  2. Found my new drivetrain...
    Last Post: 09/20/2011, 08:14 AM
  3. Drivetrain noise gone!!!
    By VX crazy in forum Ldub's After Midnight Topics
    Last Post: 07/07/2011, 07:37 AM
  4. VX drivetrain descended from?
    By haulin79 in forum VX Talk...
    Last Post: 06/26/2006, 05:43 AM
  5. Clunk Sound in the drivetrain
    By dtruax in forum VX Talk...
    Last Post: 06/25/2003, 04:13 PM
