Results 1 to 15 of 15
Thread: Blind-Spotz mirrors
    Blind-Spotz mirrors
    These are supposed to be for a ford, but they fit and work very well. They are beveled (thick at the top outside corners) and give very good view of the blindspot and even some rear coverage with proper aiming.
    May 2002
    2000, Proton Yellow, VX, 0584
    The pics that get uploaded directly to the post are store in a way that they need to be small in file size and only in gif, jpg, jpeg or png. Bit maps are not compressed so the take up a lot of space.
    Something of that size needs to be uploaded to the gallery, then you can link to it.. Or convert the image to a gif or jpg and I'm sure it'll go. Sorry
    Scott / moncha.com
    Got it .
    Thanks WSG.
    2001, Kaiser Silver, 841
    Surge, except for the fact that they fit nicely into the corner of the mirror, are they any different from the regualr circular and rectanglar stick on blind spot mirrors?
    How about a part number, manufacturer, price, etc? I use the round one that rotate so you can see up, down, sideways -whichever is more helpful to you but I like how these look and they are bigger without being overwhelming.
    I think they're the perfect compromise between round and rectangular. Also, they're thicker at the top outer edge. After comparing to round/ rect., I think the added spacing at the corner gives this mirror a better viewing area. AND it's the perfect size.
    Pretty sure it was PEP Boys. I'll post pics of the package tomm.
    Blind Spotz. Part#8912. Mfg. by Steel Horse Automotive .
    601 W.Walnut St. Compton, Ca. 90220 .
    Ph#310-537-0837.
    Available through PepBoys for $5.99 pr.
    THANK YOU! I’m off to PepBoys tomorrow!
    Glad to be of service. I think they're marked L&R and used on the indicated sides.
    P.S. keep that s/c on ice for me.
    G'bye tax return!
    Nov 2002
    1999,Astral Silver,0889
    Hey Sarge Thanx for the post. I'll diffently be at pep boys tomorrow as well. Hey Tone see you there. Oh wait maybe not. I keep forgetting that your in Texas and I'm in RI sorry.
    My Bad.
    Tony "TDAWG" Rodriguez
    99 Astral Silver 0889
    Yep, thanks sarge.
    I'll swap my stick-ons for these too.
    You're welcome. These are stick-on as well.
    Another similar brand
    They were out of that model Steelhorse @ PepBoys but had a similar one that was $2.99 each. Made by Custom Accessories, Niles, CA called Blind Spot Mirror p/n 71118 - I think the larger size is going to be helpful as between the very dark tint and small circular ones I had, I had to really check hard for vehicles at least on the passenger side.
    I think I looked at those and test fitted too. The wider Blind Spotz mirror lets you swing the factory mirror out farther for a better view in the factory mirror. I think the bevel on Blind spotz is different also. It's tapered from the top outside to the bottom inside which gave me a better low and rear view.
    Yeah, I bought just one to test and am finding this one does not aim down and in towards the blind spot as much as I would like. It was getting dark when I put it on so will test more tomorrow.
  1. Maxi View Blind Spot Mirror -- World's Best?
    By RallyDude in forum VX Modifications...
    Last Post: 01/14/2011, 08:09 AM
  2. Replies: 3
    Last Post: 08/15/2010, 03:55 PM
  3. Auto Blind Spot Mirror Adjustments
    By Knigh7s in forum VX Modifications...
    Last Post: 06/30/2008, 04:31 PM
  4. Kill your blind spot in ten seconds
    By cascabel3 in forum General Tips...
    Last Post: 02/15/2008, 09:37 AM
  5. Blind spot cure!
    By ZEUS in forum VX Modifications...
    Last Post: 12/20/2006, 02:19 PM
