Results 1 to 15 of 29
Thread: WINDOW FIX FROM ISUZU!!!! Finally....
    Mar 2004
    2001,Silver,VX,0345
    Not positive if someone has already posted this info, I just know that every VX owner I talk to has the same issue, the Windows.
    I have not had a single issue with my VX except the windows keep getting out of track and are just generally messed up. Well after two years of constant repair work (I just get my windows fixed every time I take it in for an oil change) my Service Advisor finally tells me that Isuzu released a fix for the window issue. As I write this my VX is at the body shop (yeah thats right) at the body shop getting the window rails spot welded into new positions. I'll get some more info from them when I pick it up and let you know how it works, I'm just on cloud nine and had to share with everyone that there is hope. Now if they could just fix the headlight seals........
    Jul 2004
    2000 Black VX 0363
    Mine just went in and they said that the window regulators needed to be replaced, per isuzu's instructions. Apparently there are new ones out for it.
    Also be careful that if they spot weld anything to the inside of the door, that it doesn't deform anything on the outside finish. That could get ugly.
    2000 Black VX 105k
    Tad, just to let you know... not sure if "per Isuzu's instructions" mean the NEW instructions Cline is talking about or not, but almost every person here (including myself) that has taken their VX in in the past for warranty window service has received new regulators. Did that fix the problem??? Yeah, for about a week or so... then it started doing the same thing all over again...
    It's a design flaw that, I hope, Isuzu has acknowledged and is truely fixing in this new "fix".
    Ya, keep us updated on this, cause after reading this post, I called my buddy Tom who is a service manager at a local Isuzu dealer here, and he said he has heard no such thing. Said he would call an Isuzy rep (we all know how that goes) and see if something has come across the wire, but up to now, he knows of no fix.
    Like most other car manufacturers do, Isuzu should send out a letter staing this fix to all Isuzu owners, especially those still under warranty. I think pigs will fall out of my arse first though.
    Mar 2004
    2001,Silver,VX,0345
    Yeah I made buddies with the guy because I run a 4X4 Off Road Park near S.A. that he has visited with his club a few times, so he actually called up Isuzu for me and hunted down the issue. Soon as I get some more info I will let everyone know. Regarding the regulators I have had mine changed about 4 times. And I'm pretty sure they won't be doing any welding to my outside panels, if so guess who is getting a new VX courtesy of Isuzu.
    Jul 2004
    2000 Black VX 0363
    thats not what I meant.
    If they tack weld something to the inside of your door, it means that on the OTHER side of that piece of sheet metal, is the outside of your car, aka the paintjob.
    Unfortunately, paint does weird things when subjected to heats that turn metal molten; even if it is for a short time.
    Hell, even chrome burns.
    Ok, but I'm pretty sure the window rails aren't attached to the inside of the doors. I believe the rails are actually attached to brackets, which are attached to each side of the inner door.
    Jul 2004
    2000 Black VX 0363
    okie cool then.
    just making sure
    May 2004
    No VX anymore. :(
    That is correct. If the window rails were attached to the outside sheet metal, that would mean you'd have rivets or bolts sticking out of your paint!
    Steve
    May 2004
    Used to own #777
    Well, what's the word?
    I've priced a set of hot-rod window regulators. They actually aren't all that expensive. Something like $70 each for a set that uses your original window guides to hold the window.
    -Tad
    Jun 2003
    99, Ironman VX, 1455
    I'm having the same problem as everyone else and am looking for a fix too. If this FIX is it, I am giong to have to find an Isuzu service place....
    If not, can I get the information for the HotRod window regulators.
    -The Rave-
    North Carolina
    Jul 2004
    2000 Black VX 0363
    NC_VX:
    I just got new window regulators put in mine and it works like new. People here say that'll last for a couple weeks and go out again.
    About taking it to an isuzu place, it seems they've all shut their doors around here. University Isuzu over in Durham was the closest place but it doesn't even deal with them anymore.
    I'm thinking about calling TAO auto here in Raleigh on Capital Blvd. They specialize in Honda/Acuras but I'm willing to bet they'd do Isuzus too thanks in part to the Passport and SLX Isuzu relationship. They might be receptive.
    Sorry to thread hijack.
    Tad, that's probably the best thing to do. I think we've come to the conclusion that the original window track design is the problem, causing the binding with the weather striping and, sometimes, causing the regulators to overheat and die.
    If the shop can play with it and see exactly where the problem lies, surely they can mock something up to make it work.
    97 Red VX 0673
    Window adjustment
    Before the crash of the site I posted my window fix on a thread. I suggest anyone with the window problem gives it a try because it's real easy and costs nothing.
    If you take the inner panel off you will see the plastic units that are bonded to the window and then bolted to the raise lower mechanism plate.
    If the plastic units have not been damaged it's possible to adjust their position.
    The bolts that hold the plastic to the plate have lock nuts on the back (this is not obvious but you'll work it out if you look). First slacken off both lock nuts then the bolts themselves, this then allows you to be able to slide the platic units and therefore the glass back about 10mm, this is sufficient to stop the window binding.
    I did this several weeks ago and have had no problems since.
    I had promised to post pictures but it means taking my panel off again but if anyone truly can't work it out I'll do pictures.
    Col
    Apr 2003
    2001,Proton,????
    Yes, please post pictures when you have a chance, I own three of these VX's, and have removed the panels on all three, and I just don't see the adjustment you are talking about.
  1. Finally did my window mod thing
    By Bob Barker in forum VX Modifications...
    Last Post: 03/24/2013, 07:43 PM
  2. Finally : NEW PERMANENT WINDOW FIX !
    By maxw in forum VX Troubleshooting...
    Last Post: 06/14/2009, 09:50 PM
  3. Window Issue - Regulator and Window Strip
    Last Post: 01/13/2009, 11:31 AM
  4. Official Isuzu window fix!
    By SGT.BATGUANO in forum VX Troubleshooting...
    Last Post: 08/10/2005, 03:08 AM
  5. Driver Window Problems & ISUZU Dealers
    By BeeVenom in forum VX Troubleshooting...
    Last Post: 10/02/2004, 08:34 AM
