Results 1 to 10 of 10
Thread: Cool Accessories...
    May 2004
    Used to own #777
    Cool Accessories...
    I know that many of you guys/gals buy item after item for your VXs. I'm fairly new to the board and have missed the years of "This sucks" and "This rocks" posts and thought that I'd start a post where people can post their "best of the best" VX type items.
    For example, on my Trooper, the thing that people probably comment on the most is my Maglight mount. I have two Maglight mounting clips screwed to the driver's door right below the door handle/arm rest. It's right where I can easily get at it, but it is never in the way.
    I know on the VX, a set of jumper cables coiled up will fit perfectly in the spare tire.
    I guess my contribution is the Trooper cup holder (for which there is another post describing it).
    So, what is on your top-10 list?
    -Tad
    Jul 2004
    2000 Black VX 0363
    I set of 33's on some rockcrawlers :P
    If only I didn't care about my warranty.
    2000 Black VX 105k
    1999 White Ironman 0769
    A pair of raised lip, black, rubber floor mats from Walmart that fit over the originals like they were made for them. They were $5.99 when I got them. Walmarts "Good" label.
    Drivers pillar, dual gauge pod with Oil Press & Voltage guage.
    Do a search for Gauge pods to see the post W/pic.
    IPF driving & fog lights mounted on brush bar. Improved night driving visability 100%.
    Thule 32" fairing in front of roof bars cut the wind noise to a reasonable level.
    Dynamatting the vehicle reduced the interior noise level. It's worth doing at least the doors because of how much it changes the noise level.
    But they're sure fun!
    Jan 2004
    2000 Yellow VX 0648
    Hey,
    The Thule 32" fairing. Is that a VX specific part or a universal one. I would like to possibly get that. I think it would not only cut the wind noise, but look good too...
    Dean
    Smile
    NJVX, Its the universal one and it has everything you can use to mount it to the VX bars.
    Jul 2004
    2000 Black VX 0363
    Just a quick note here.
    You'd think that the 32" yakima fairing would fit perfect
    BUT IT DOESN'T
    Learn from my mistakes kids. The mounting clips on the yakima are to small to fit around the bars.
    I'm out $50 now.
    2001, Proton Yellow, #0580
    Seems like someone else got that fairing and got it to fit - used the horizontal mount wingrider clips (from Isuzu) and mounted extended brackets or something - it may have been a thule deflector...
    -- John
    Jan 2004
    1999 Silver VCross 1925
    Yakima fairing
    Hey guys, I had the Yakima fairing and mounted it just fine. What I did was cut the mounting clips just where the curvature starts, then remove your roof rack for easy measuring and marking. Assemble the fairing and mounting clips and place on top of the rack. Mark your spots and drill holes through the rack. I did it removing the weather strip and after the holes were drilled and the fairing fitted, I re-mounted the weather strip and drilled a little smaller holes through it. I then mounted the whole thing together with the boltheads on top for a more factory look, you will need some kind of spacers for the bolts, flat, and pressure washers, it is really easy to figure out as you are fitting the whole thing together.
    Good luck,
    Julio
    Jul 2004
    2000 Black VX 0363
    I've got some machine screws sitting at home I may just use to attach it.
    Jan 2004
    Fairing
    Here is a not so good pic, but it gives you an idea of the finished work.
  1. AfterShock VX accessories!
    By ron in forum Miscellaneous Items For Sale
    Last Post: 01/17/2017, 05:14 PM
  2. Looking for grille, no accessories needed
    By WormGod in forum Archives
    Last Post: 06/17/2016, 06:59 AM
  3. Body Exterior Accessories
    By intdesign03 in forum VX Modifications...
    Last Post: 06/30/2013, 06:16 PM
  4. Power For Accessories?
    By eblank in forum VX Modifications...
    Last Post: 06/01/2011, 08:33 PM
  5. Japanese VX Modifications Accessories
    By momaster in forum Japanese Domestic Model (JDM) VXs
    Last Post: 01/25/2011, 06:40 AM
