OK heres what I have decided on....
I am doing the 912's, 2" poly spacer, 1.5" drop brackets, crank torsion bar, and fitting 33"x12.5 TrXus MT tires. That should be a 4.5" lift that will give the 33"s some clearance. Wow this is going to be a bit bigger then I originally expected!  It will sit about 6" higher with the tires!
Now what size shocks should I be looking for front and rear? What is your opinions on Bilstein 5150 series? What valving (stiff) should I look for?
