I’ve recently developed an alignment problem that is stumping both me and my local mechanic. I have an appointment with Isuzu, but knowing how crappy factory mechanics can be, I’d love some feedback from you guys before I go in . . .
The problem is, my driver’s side wheel appears to sit about 1/2" - 3/4” further forward in its fender-well than does the passenger side front wheel. The difference in distance between the front of the tire and the inner edge of the cladding (where I cut it to fit the Nittos) is clearly visible between one side and the other. The VX also pulls ever-so-slightly to the driver’s side at highway speeds.
I figured this was simply an “offset”: condition caused by caster being out of whack. But my alignment guy couldn’t fix it (incompetence?), and the VX manual says caster isn’t something you can see with the naked eye. The frame is not bent, and all the parts look to be undamaged. Anybody got any idea what the heck I am looking at? What is wrong here?
Help would be greatly (and desperately) appreciated!
Thanks,
Ron
