Royal Purple Help Needed
					I'm going to take the advice of so many of you on Royal Purple.  I've checked ALL the treads and need a little more help.
I have a few questions:
1.  Front and Rear Differentials-  Do I use Royal Purple 75W-90 or Royal Purle SyntroMax?  How many quarts do I need to buy?
2.  Is the tranny fluid and the transfer case fluid the same type? What is the name of the fluid I need?  Is it AFT Royal Purple?  I think if I do a partal change I will need 4 qts for the tranny and 4 for the tranfer case.  I think I would like to do a COMPLETE flush. If I do a COMPLETE flush, how many quarts do I need?
3.  Is there anything else I should know or be aware of?  Tone's advice to use teflon sealer on the threads of the bolts is something I wasn't aware of.
4.  I have 30 ks on my VX.  Would it be alright to switch to Royal Purple Oil Fluid now?  If it is o.k., how often should I change the fluids?  Right now I change the oil every 3 ks.
Thanks for your expertise.
Peace.
