I test fitted the nitto's at 285/60 and it seemed like the tire only hit after turning sharply. I'm wondering if a 275/65, which is a little narrower, will slide by the cladding even though it is slightly taller. And for those of you who said you didnt have to trim the 285/60's fpr the terra grapplers...youre magicians because there is no way those bad boys will fit on mine without cutting. I wasnt looking for a tire as aggressive so im just going with some cheap bfgoodrich rugged trail tires.
