Results 1 to 12 of 12
Thread: Lift Question Please help
    Sep 2003
    1999,silver,vx,1565
    I am planning to do the 3" Spring lift convertion to my VX.
    I already bought the OME912 Springs. I am also installing the Rancho 9000x shocks, which I already bought.
    I have been checking several sites that offer lift kits, and found that they also include
    1) 2" POLY COIL SPACER,
    2) 4" BALL JOINT SPACERS,
    3) 2" Bumpstop Extention
    4) LOW PROFILE UPPER A-ARM BUMPSTOPS
    5) REAR AXLE BRAKE LINE "T" EXTENSION
    Are all these items really necessary?
    The extensions are rather cheap, but the 2" Poly spacers are $100 and the 4" ball joint spacer is $45.
    Let me know what you guys think. Should I also install all these extra items?
    Will I get more than 3" lift?
    Will I get better alignment and a smother ride?
    These are statements that these sites claim.
    I found these items in these sites:
    http://www.independent4x.bigstep.com...0&PRID=1247371
    http://www.darlington-offroad.com/ca...?UCIDs=1031042
    Feb 2004
    99 White Ironman
    First..do a search. The answers are there.
    I'm waiting for my OME 912 springs to arrive. (Don't order throught Rocky Road off road in Colorado- say one day, then the next and so on. I've been waiting for weeks)
    Anyhow, from what I have read here, you do not need all that stuff. However, Swordy did mention something about the Bumpstops. You may want to ask him.
    Again, do a search..ALL the answers are there.
    Feb 2004
    1999 vehicross 0265
    lift
    Hey, I just finished a 3 inch calmini suspension lift. It came with almost everything. For the ball joint I just fliped it from above the controll arm, to below it. With the suspension installed(and the torsion bars tightened) I have a gain of about4 inches in the front and 3.25 in the rear for a nice stance. I also have a 3 inch body lift to give the extra room for my 36 inch tires. As far as an allignment goes, I had to flip the ball joint before it could be done due to toe in. After the flip it was alligned perfectly. I hope that helps.
    Mar 2004
    A-2004
    dstruction.
    Does the, 36" tires. Lift and 3' body lift make the VX feel unstable around town? Was it a trooper body lift?
    Can you post pics?
    Would 33x14.5 width tires fit easy with that setup?
    Thanks,
    2001 Proton 0405
    Re: Lift Question Please help
    [/QUOTE]These are statements that these sites claim.
    http://www.darlington-offroad.com/ca...?UCIDs=1031042 [/B][/QUOTE]
    Matt at independent 4x, and Joe Darlington of Darlington-offroad are both great people and wouldn't lead you astray. They would BOTH go out of their way to help you if you have any problems installing your lift. We've had the pleasure of meeting both of these great guys at Moab Zu's and would highly reccomend them.
    Good luck on your lift
    Deby
    Improve the desert.... plant a Sierra Club Member!
    Sep 2003
    1999,silver,vx,1565
    Hey,
    Thanks to everyone for your responses. With your inputs and a search on "spring lift" I got most of my questions answered.
    I think I'm just going to install my OME912s and do the ball joint flip. I will do buy the rear bump stop extensions since they are only $15
    Although I am still not clear of the function of the 1/4" BALL JOINT SPACERS. Is this spacer used to alleviate pressure to the CV joints caused by the cranking of the torsion bars?
    I will post pictures after I get the lift done and my new 33s on. Like someone said in another post. "Mods are addictive, you do one and you are hooked"
    I have a long wish list......... reinforced torsion bars and tie rods, a pre-runner bar, and maybe a winch. It will take and lots of time and $$$ but some day it'll get done!
    '99 Astral #1977
    Originally posted by VXspaceship
    Hey,
    First off, let me say that I am not lifted.. but have done alot research and want to be lifted soon. It's a race, almost, between me and Nocturnal...right Gil?
    What you posted is really all you need to do. The 1/4" ball joint spacers are just to get your alignment closer to spec.
    RichD
    My VehiCROSS
    Mar 2004
    A-2004
    919?
    Just an FYI...
    There are some posts on sagging issues on the 912 calimini lift. Here is a LINK
    Some suggested 913 or 919.
    Cheers,
    Feb 2004
    1999 vehicross 0265
    lifted
    vx sapceship, Hey. Sorry ot took so long to reply, too much work. Anyway, Last weekend I went off roading and beach riding. The only thing that I noticed with the lift and tires was the wheelie effect. I got pretty wild and had no problems with the side to side role. I seemed to loose a litle steering mobing up steep hills. I think 33 is the way to go. I had minor triming on the inside front cladding to fit the 36. I'll post pics when I figure out how, I haven't figured it out yet. (i'm not much of a computer guy. Later
    Jun 2003
    visiting your planet, from time to time
    Just to clarify,
    912's do not come with the calmini kit, "calmini" springs do.
    The 912's have NOT been reported as having a sag problem. 912's are "OME" springs
    2001, Proton Yellow 0911
    Loosers....
    LMAO
    My Other Ride Is a Puma
    www.mwior.com
  1. To lift or not to lift that is the question
    By CatFish in forum VX Talk...
    Last Post: 03/28/2012, 04:15 PM
  2. another lift question...
    By xman in forum VX Modifications...
    Last Post: 10/13/2008, 02:59 PM
  3. lift question
    By drummysvx in forum VX Troubleshooting...
    Last Post: 05/30/2007, 02:28 PM
  4. Lift Question...
    By grober02 in forum VX Modifications...
    Last Post: 03/22/2007, 09:38 AM
  5. Lift Question
    Last Post: 04/28/2006, 01:28 PM
