Results 1 to 15 of 42
Thread: Brake rotor issues
hitnrun74 Brake rotor issues 07/02/2004, 08:44 PM
Andrey same stuff here... was told... 07/02/2004, 09:16 PM
hitnrun74 At least the replacements... 07/03/2004, 03:59 AM
Andrey I had it done by a shop... 07/03/2004, 05:18 AM
VX4EJR Re: Brake rotor issues 07/03/2004, 04:45 PM
shoota77 same thing happened on... 07/04/2004, 12:07 AM
hitnrun74 I put front rotors (89$ each... 07/04/2004, 08:13 PM
MachineVX I had the same problems with... 07/04/2004, 09:17 PM
CrzyFool The Isuzu Rotors are crap and... 07/05/2005, 12:45 PM
Tone Gee Crazy Fool, mine and... 07/05/2005, 01:59 PM
Maugan_VX Gotta go with Tone on this... 07/05/2005, 03:52 PM
Reg Hinnant 94,000 miles with the... 07/07/2005, 07:06 AM
psychos2 Tone , just because yours are... 07/07/2005, 09:49 AM
driver3 Mine lasted 78k, the rotors... 07/07/2005, 01:34 PM
drdavidr4u Same here, had to replace my... 07/07/2005, 03:58 PM
WyrreJ I am detecting a pattern - 3... 07/07/2005, 08:30 PM
V-Twin hiCROSS My rear rotors "dissolved" as... 07/08/2005, 10:10 AM
driver3 Mine were all Ohio miles..... 07/08/2005, 11:31 AM
Ldub The s/s braid lines aren't... 07/08/2005, 03:08 PM
psychos2 yes but the salt did not eat... 07/08/2005, 03:08 PM
MarkChai Ceramic pads eat rotors. 07/12/2005, 11:31 AM
psychos2 like you said thats his... 07/12/2005, 03:23 PM
Maugan_VX The ceramic pads are harder... 07/12/2005, 04:28 PM
psychos2 maugan_vx, how do you know i... 07/12/2005, 07:30 PM
Maugan_VX After reading that post.... ... 07/12/2005, 08:21 PM
psychos2 maugan_ vx, you have no clue... 07/12/2005, 08:29 PM
Moncha I guess we could say some of... 07/13/2005, 08:05 AM
VXtreme I have got 71,200 miles on my... 07/13/2005, 09:09 AM
Maugan_VX Well isuzu probably... 07/13/2005, 10:20 AM
Hotsauce I have tried in total 6... 07/13/2005, 03:38 PM
Eckstream I just replaced all rotors... 11/02/2005, 07:12 AM
Jonnie Not true. Jonnie 03/18/2006, 08:03 PM
Chopper Just to throw some gas on... 03/19/2006, 06:58 PM
ISCE Just had to replace all 4... 07/29/2006, 08:38 AM
kpaske So it seems to me that most... 07/30/2006, 06:54 AM
Ldub I believe Mbeach has had a... 07/30/2006, 07:05 AM
Doug brake rotor issues 07/31/2006, 09:46 AM
ISCE ...ABS rings seized too... 07/31/2006, 10:29 AM
psychos2 here are pics of what mune... 07/31/2006, 01:42 PM
Doug I can't image the ABS rings... 07/31/2006, 05:47 PM
    Previous owner of #1068
    Just had to replace all 4 rotors - completely rotted out
    Hate to dig this thread up, but add another VX to the trashed/rotted out rotors. I've not had any brake problems at all, braking seemed fine. Two days ago while braking felt a slight grinding feeling. By yesterday coming home from work a definitely grinding feel and sound when braking.
    When I took a quick look visually they looked completely rusted out. The right rear was the worse with only a very small strip that was more polished. All 4 looked horrible. The shop just called and all 4 rotors are trashed, rusted/rotted beyond repair.
    I am right at 30K. This is MD and we don't get a lot of snow, but when it does they do put a lot of salt on the road. My guess is bad steel and the salt maybe? Seems quite a few discussions all around the same 30K with trashed rotors.
    '99 Ebony VX #0038
    So it seems to me that most of the Veteran members agree that the stock rotors and pads are the best combination available for the VX. I am getting ready to replace all four at just over 100k. Had the fronts turned once, but I've used several different types of pads. In retrospect I think the stock pads lasted the longest so I'm convinced that the conventional wisdom here is correct. I was hoping for the modern look of some painted/slotted rotors, but if they are all garbage I'll just stick with stock. Is there anyone else who has a positive experience with aftermarket rotors?
    I believe Mbeach has had a couple of posts where he's indicated positive experiences with aftermarket rotors...unfortunately, I can't remember which brand.
    Personally, I like the OEM pads because they work well & have NO brake dust that I've ever seen.
    Mar 2004
    01, Proton Yellow, 1233
    brake rotor issues
    Obviously there is a range of experience with the OEM rotors. I just replaced mine about two weeks ago and took pictures to post, assuming I was just doing a brake job. I was surprised to see the inside face of both rotors were, for lack of a better term, delaminating. Hopefully these pictures will help some in this thread.
    Knowing the VX is over 4K lbs I bought a well machined, OEM spec thickness rotor. They are by Raybestos at $110 each. If you purchase aftermarket rotors check to see that the three smaller holes for the ABS ring are present.
    I plan to post all the pictures from the front break replacement, including where to get those three tiny screws that are sure to strip...
    ...speaking of ABS ring. The shop just called and said mine were seized onto the rotor and both front rings broke when trying to take them off... How much should these cost? And, how long to put on? I am starting to feel like I am getting ripped off.
    He said his thought is that since the vehicle doesn't get driven that much, I am at 30K for a 2001, that the corrosion and moisture wasn't kept off the rotors causing the damage. This is my daily driver, but I only have a 12 mi commute ea way, so we are only talking approx 120 miles/week, but they have been daily. All until recently here when I bought another motorcycle to save gas money. Now, with the brake job due to not driving it anything I saved is gone.
    1999, Ebony Black, VX ,1976
    here are pics of what mune looked like. shawn
    1COOLVX
    Mar 2004
    I can't image the ABS rings ceasing to the rotor. Almost certainly, they gave them a beating(s). I would humbly insist they replace them at no cost. They were not broken when you came in. They butt against the rotor an are held in w3 bolts at about 24ft-lbs. A few drops of penetrating fluid...
    '99 Ebony VX #0038
    I can tell you this much - I've got a 1999 with over 105k miles on it. My fronts have been turned once, and both front and rear are about due for replacement due to normal wear (except for the one rear rotor which I've trashed, but we won't get into that!). Even today they don't look anything like those last couple of pictures. There is rusting on the edges, but the surfaces where the pads make contact are reflective and shiny. There was either a BIG difference between manufacturers, or some set of conditions allowed your rotors to deteriorate unusually fast. Did your VX sit for a long period of time? Perhaps at the dealership before it was sold? I know some brand new 2001 models sat well into 2003. Perhaps allowing the rust to build up weakened them and allowed them to break down?
  1. Brake issues
    Last Post: 07/27/2012, 06:54 AM
  2. Need Help Rotor Install
    Last Post: 11/14/2011, 08:22 AM
  3. New Rotor and Brake Pad Install - It's Great!
    By BeeVenom in forum VX Modifications...
    Last Post: 03/02/2011, 09:23 AM
  4. BRAKE Issues
    By ojmagg in forum VX Troubleshooting...
    Last Post: 04/20/2004, 11:28 AM
  5. brake pads/rotor change
    By dutchie in forum VX Talk...
    Last Post: 11/16/2003, 07:16 AM
