For what ever it's worth. Just did the front pads today on one of our '99's. They were original with 99,891 miles (Also, did the timing belt for $200, all inclusive). Replaced them with OEM for $119.00 for the pads alone, plus $37.00 labor. The rotors were fine, as is.
@140,000+ real miles
, Change the upper and lower radiator hose??? Na!!!...How bout the transmission fluid?? Ahh yes the transmission...I'm glad I asked myself that question ;oor; ...well after all these miles For some reason, I started experiencing a "soft shift" in the gear changes. This is a very general symptom of a pending clutch pack failure in many GM trannys( in the latter part of the previous century), usually brought on by a low fluid level or "mucho" full throttle events during the gear changes.
I'm about 4K miles short of 150K on the odometer...Im gonna try to make it...when I do replace those pads its going to be OEM for sure...
