well...I just changed out all the brake pads today...After calling around I decided on Raybestos's #1 pads...cost me roughly $45 for fronts and $35 for rears.
My original front pads were immaculate with about 50% or better left on them at 38,000 miles...
The rear pads were similarly worn in that the inner pads (closest to the caliper piston) were shot while the outer pads (closest to wheel studs) were about as good as the fronts... I'm thinking pistons were hanging up on the inner pads, or caliper slides "sticking"?
I took the slides apart and wire brushed and flushed out the inside of the slide "tubes" with brake cleaner; then re-greased them with Raybestos 100% silicon grease while cleaning off the slide "rods" and smearing some grease on them. Also "Never-Seized" all threaded bolts.
I flushed out the caliper pistons with brake cleaner and sprayed some silicon spray after they dried...all wheels seemed to funtion normally after applying the brake pedal as the calipers seemed to
release normally.
I also siphoned out some of the brake fluid in the master cylinder resevoir beforehand to compensate for the pistons being in a more retracted state due to the thickness of the new pads.
