Is there 4 of these clips(white nylon/teflon) that run the track? if so I'm missing one causing the window to rock anyone else here have the same problem? possible solution? thanksOriginally posted by Kahuna
Unfortunately, the clips are not replacable. I called everybody on this matter. Everybody told me I had to buy a new window and that the clips are mounted permanetly to the glass. That's why I made my own. You see, if the clips hold the window can not be thrown forward. It stays where it is suppose to.
