Results 1 to 2 of 2
Thread: Wheel Offset downside??
    Aug 2003
    2001, Dragon Green #0891 [retired ;_;]
    Is there a off-roading downside to wheel offset? Is there any stability issue that might arise from light to medium offroading in a setup like wormgod has
    or is somthing like daver has better for offroading?
    I know tires make a difference, just interested in wheel info. Will the amount of offset reduce the stability of the truck while offroading? Or is it basically anything you can get to fit will really work and there really wont be a downside either way?
    my ride
    looks like the top one. and i don't think i'd ever take it off-raoding with that wheel set. 16's to 18's are ok. the others are too expensive so would you really want to go off-roading with them? and you would not get enough rubber to keep the rims safe, especially if you have to let some of the air out of the tires.
    Hotwheels� toy come to life.
    www.doubleadesign.com
  1. Wheel offset
    By Intrepid_Vanguard in forum VX Troubleshooting...
    Last Post: 04/26/2014, 04:15 PM
  2. wheel advice offset/backspacing
    By djvx in forum VX Talk...
    Last Post: 06/12/2010, 08:04 AM
  3. Wheel Offset Calculation Help
    Last Post: 01/25/2009, 09:34 AM
  4. Offset
    By CrnCnn in forum VX Modifications...
    Last Post: 03/20/2007, 06:51 PM
  5. What's an offset?
    By Medman in forum VX Talk...
    Last Post: 06/26/2004, 07:17 PM
