Results 16 to 16 of 16
Thread: Good General VX Info
Threaded View
    Nov 2002
    Lightbulb Good General VX Info
    I know this info is readily available but thought it would be nice to have in one combined format, especially the capacities. Enjoy!
    KEY SPECS 2001 ISUZU VEHICROSS
    6VE1 ENGINE SPECS
    Type: V6, 3.5L, belt/gear-driven DOHC, four valves,
    open-deck aluminum block and aluminum heads
    Displacement: 3494cc (213 cid)
    Bore x stroke: 93.4 x 85mm (3.677 x 3.346 in.)
    Horsepower: 215 hp @ 5,400 rpm
    Torque: 230 ft.-lbs. @ 3,000 rpm
    Compression ratio: 9.1:1
    Emission control: EGR, EVAP
    Fuel system: General Motors
    Fuel pressure: 42-55 psi unregulated, 3-15 psi lower Q idle
    Fuel injectors: 11.8-12.6 ohms
    Oil pressure: 57-80 psi @ 3,000 rpm
    Valve clearance: Intake: 0.009-0.013 in. (0.23-0.33mm);
    Exhaust: 0.010-0.014 in. (0.25-0.35mm)
    Spark plug gap: 0.040 in. (1.05mm)
    Firing order: 1-2-3-4-5-6 (Odd on right bank)
    Ignition timing: 20[degrees] @ idle
    Base Idle speed: 750 rpm
    ELECTRICAL SYSTEM
    Battery: 12V, 582 amps
    Alternator: 90 amps
    Ignition: Direct
    CAPACITIES
    Oil change: w/filter 4.3 qt. (4.0L)
    Automatic trans: 9.1 qt. (8.6L)
    Transfer case: 2.0 qt. (1.9L)
    Front differential: 1.5 qt. (1.4L)
    Rear differential: 3.2 qt. (3.0L)
    Fuel tank: 22.5 gal. (85L)
    Cooling system: 7.4 qt. (7.1L)
    Refrigerant: R134a, 1.43 lb. (650g)
    Compressor: PAG, 3.0 oz. (90cc)
    LUBRICANTS
    Brake fluid: DOT 3
    Engine oil: API SE or newer, SAE 10W-30
    Automatic trans oil: Dexron III
    Transfer case oil: Dexron III
    Differential/axle oil: GL5, SAE 75W-90
    Power steering: Dexron III
    MAINTENANCE SCHEDULE
    Oil and fixer: 7,500 miles
    Coolant: 30,000 miles or two years
    Spark plugs: 100,000 miles
    Timing belt 100,000 miles
    Transfer case/axles: 15,000 miles
    Front hub grease: 30,000 miles
    CHASSIS SPECS
    Drivetrain: Rear/AWD, four-speed automatic transmission
    w/overdrive, automatic transfer case,
    limited slip differentials. See Technical
    Notes.
    Brake system: Disc/disc, three-channel ABS with G-sensor
    for off-road
    WS sensors: 1,300-1,900 ohms
    Front disc thickness: 0.969 in. (24.6mm) minimum
    Rear disc thickness: 0.654 in. (16.6mm) minimum
    SUSPENSION SYSTEM
    Front: Upper and lower wishbones, torsion bars,
    stabilizer bar
    Rear: Solid axle, coil springs, 3 trailing links,
    one lateral link, stabilizer bar
    Lug nut torque: 87 ft.-lbs. (118 Nm)
    FRONT ALIGNMENT SPECS
    Toe: 0 [+ or -] 2mm (0.0 [+ or -] 0.080 in.)
    Camber: 0[degrees]0' [+ or -] 0[degrees]30'
    Caster: 2[degrees]10' [+ or -] 45'
  1. Replies: 25
    Last Post: 06/22/2011, 10:37 AM
  2. General VX Questions
    By RickOKC in forum VX Talk...
    Last Post: 11/18/2010, 01:03 PM
  3. CEL: 342 - Good info
    Last Post: 04/12/2010, 08:15 AM
  4. General stuff...
    Last Post: 10/29/2007, 09:30 AM
  5. Need Good Info!!!
    By krill in forum VX Talk...
    Last Post: 09/06/2006, 09:05 PM
