I know this info is readily available but thought it would be nice to have in one combined format, especially the capacities. Enjoy!
KEY SPECS 2001 ISUZU VEHICROSS
6VE1 ENGINE SPECS
Type: V6, 3.5L, belt/gear-driven DOHC, four valves,
open-deck aluminum block and aluminum heads
Displacement: 3494cc (213 cid)
Bore x stroke: 93.4 x 85mm (3.677 x 3.346 in.)
Horsepower: 215 hp @ 5,400 rpm
Torque: 230 ft.-lbs. @ 3,000 rpm
Compression ratio: 9.1:1
Emission control: EGR, EVAP
Fuel system: General Motors
Fuel pressure: 42-55 psi unregulated, 3-15 psi lower Q idle
Fuel injectors: 11.8-12.6 ohms
Oil pressure: 57-80 psi @ 3,000 rpm
Valve clearance: Intake: 0.009-0.013 in. (0.23-0.33mm);
Exhaust: 0.010-0.014 in. (0.25-0.35mm)
Spark plug gap: 0.040 in. (1.05mm)
Firing order: 1-2-3-4-5-6 (Odd on right bank)
Ignition timing: 20[degrees] @ idle
Base Idle speed: 750 rpm
ELECTRICAL SYSTEM
Battery: 12V, 582 amps
Alternator: 90 amps
Ignition: Direct
CAPACITIES
Oil change: w/filter 4.3 qt. (4.0L)
Automatic trans: 9.1 qt. (8.6L)
Transfer case: 2.0 qt. (1.9L)
Front differential: 1.5 qt. (1.4L)
Rear differential: 3.2 qt. (3.0L)
Fuel tank: 22.5 gal. (85L)
Cooling system: 7.4 qt. (7.1L)
Refrigerant: R134a, 1.43 lb. (650g)
Compressor: PAG, 3.0 oz. (90cc)
LUBRICANTS
Brake fluid: DOT 3
Engine oil: API SE or newer, SAE 10W-30
Automatic trans oil: Dexron III
Transfer case oil: Dexron III
Differential/axle oil: GL5, SAE 75W-90
Power steering: Dexron III
MAINTENANCE SCHEDULE
Oil and fixer: 7,500 miles
Coolant: 30,000 miles or two years
Spark plugs: 100,000 miles
Timing belt 100,000 miles
Transfer case/axles: 15,000 miles
Front hub grease: 30,000 miles
CHASSIS SPECS
Drivetrain: Rear/AWD, four-speed automatic transmission
w/overdrive, automatic transfer case,
limited slip differentials. See Technical
Notes.
Brake system: Disc/disc, three-channel ABS with G-sensor
for off-road
WS sensors: 1,300-1,900 ohms
Front disc thickness: 0.969 in. (24.6mm) minimum
Rear disc thickness: 0.654 in. (16.6mm) minimum
SUSPENSION SYSTEM
Front: Upper and lower wishbones, torsion bars,
stabilizer bar
Rear: Solid axle, coil springs, 3 trailing links,
one lateral link, stabilizer bar
Lug nut torque: 87 ft.-lbs. (118 Nm)
FRONT ALIGNMENT SPECS
Toe: 0 [+ or -] 2mm (0.0 [+ or -] 0.080 in.)
Camber: 0[degrees]0' [+ or -] 0[degrees]30'
Caster: 2[degrees]10' [+ or -] 45'
