Results 1 to 5 of 5
Thread: Dropping front drive shaft
    '01 Ironman
    Is there oil or grease or anything that I will need to replace once I drop it? I am planning on doing it this weekend before I go to the track. I have installed the TOD switch, but still haven't found the correct resistance to make it work on the fly.
    Thanks,
    Alan
    '01 Proton 1416
    Question
    dropping it as in dropping it 2 inches
    or
    dropping it as in removing it completely??
    '01 Proton 1416
    Mar 2004
    A-2004
    Alaska,
    Any word on the your friends VX SAS conversion? He was suppose to begin the project in April right?
    '01 Ironman
    Removing it temporarily for the drags.
    As for the SAS his landlord jacked up his rent and he has been real busy finding another place. Will probobaly take a while.
    Feb 2003
    dropping front drive shaft
    no oil or grease to replace....unless you loosen pinion nut....but, if you do not loosen front pinion nut it is easy and doesn't take long...only rear front drive shaft bolts are a real biyatch to get off...be real careful not to damage the flange..but a flat screwdriver and hammer/mallet does the job...just be persistant..
    have to shift in and out of 4 low and neutral to move and lock drive shaft where needed to loosen bolts...
  1. Front drive shaft
    Last Post: 02/17/2017, 07:02 PM
  2. front drive shaft
    Last Post: 02/01/2015, 12:41 PM
  3. Front drive shaft help
    By cheetah2390 in forum VX Troubleshooting...
    Last Post: 05/22/2014, 04:57 PM
  4. Front drive shaft in 2WD.
    By Dumke in forum VX Talk...
    Last Post: 05/02/2013, 06:16 PM
  5. Drive Shaft Rebuilding
    By blacksambo in forum VX Troubleshooting...
    Last Post: 12/03/2011, 11:27 PM
