Check your Isuzu Vehicross service manual ( CD) under Excessive oil consumption. When you find any reference to cleaning the EGR valve under remedy please let me know. PVC Valve YES, EGR NO-EGR only shows up under emissions control. For those of you that are not mechanics perhaps the dealer will clean it for you under your emissions warranty but don't bet on it.
For those of you burning your fingers, try checking the EGR nut on every weekend before starting out, less burned fingers that way.
There are no TSBs that addresss excessive oil consumption with the possible exception of IB02-01-S004 which deals with the proper setting of Piston Rings
My Point being if the EGR really is causing the oil consumption problem then Isuzu should be held responsible, especially when your vehicle passes Emission Control checks.
Bob F
