Results 1 to 4 of 4
Thread: Check Engine Light - After PCV Replacement
    May 2004
    2001, Ebony Black, VehiCross, 0432
    Question Check Engine Light - After PCV Replacement
    I have just replaced the PCV in my VX, and now the check engine light is on. I have checked all of the connections and fit, everything looks good. Also, now until the engine is warmed up, it will stall after putting into gear. I don't know if the computer needs time to reset or if there is another issue that I am missing.
    Anyone experienced this? Does anyone have any insight into this issue? Appreiciate some help!!!
    May or may not help but its free and worth a shot...
    Did you disconnect the battery for 20 minutes or so to reset the computer?
    May 2004
    Just did this. Figured I'd give it a try, and you wrote the same thing while I was doing it (weird). Anyway, so far so good. Will update if anything goes whacky again.
    2001, Proton Yellow, #0580
    The other thing to try is to put the old one back in. It's possible that the one you bought is defective or the wrong type for the VX engine (mis-packaged).
    -- John
  1. Check Engine Light
    By vx spouse in forum VX Troubleshooting...
    Last Post: 11/24/2006, 12:15 AM
  2. Check Engine light
    Last Post: 05/19/2005, 09:30 AM
  3. !#@*! Check engine light
    Last Post: 02/27/2005, 01:47 PM
  4. check engine light
    By lenny in forum VX Talk...
    Last Post: 02/18/2004, 07:24 AM
  5. Check Engine Light...
    By dobie3 in forum VX Troubleshooting...
    Last Post: 12/11/2003, 01:45 PM
