Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: sway bar question
    Feb 2004
    2001, SUPERCHARGED!
    Welp, I went to AutoZone and bought front and rears.
    Rears went on fine, I got the wrong size bushing(larger by a hair), still put'm on.....I can slide the rear sway bar back and forth....is that bad?
    Anyone know the diameter of the front and rear sway bars?
    The fronts I could'nt put on, the braket is to long on one side.
    Draftsman of the dead
    Monchas sway bars were from Energy out of San Clemente, Ca. All sway bars as I know are hollow. Density of the material, and other properties create greater stiffness... From what I know.
    D
    face the mirror
    Feb 2004
    2001, SUPERCHARGED!
    Well, I f'd up....I have to special order the parts.
    May 2002
    2000, Proton Yellow, VX, 0584
    Yep... I went through about 10 sets to get the ones that felt right and worked correctly. I chose the grease zerk'd bushings as I was trying to rid the VX of the squeak coming from OEM bushings. I could power wash them out, take them off and clean them to no avail. The squeak always came back. The handling change was an added benefit. I no longer have a source for the bushings so I can't order them.
    The part numbers are;
    Energy Suspension
    9.5156G 3/4" (19mm) Rear
    9.5163G 28mm Front
    Good luck in the hunt.
    Scott / moncha.com
    Feb 2004
    2001, SUPERCHARGED!
    Pep Boys and AutoZone carry them(not that size), special ordered mine through PepBoys, they were a little cheaper at $18 a set....should have them in 3-5 days.
    From what others have said in the past, the Calmini bars don't provide much more stiffness than stock. Some will say they do, some will say they don't. If it is split liek this I personally wouldn't buy them.
    Now, I DID buy the bushings from Scott when he made them available and I HAVE noticed a difference here... a bit stiffer for sure.
    Feb 2004
    2001, SUPERCHARGED!
    Yea, I'm going that rought...just the bushings.
    1999, Ebony Black, VX ,1976
    you can order the bushing online from pep boys. $18.58 a set. shawn
    1COOLVX
    Calmini bars come with blue poly bushings.
    Feb 2004
    2001, SUPERCHARGED!
    I put the first set I bought on(wrong size, little big) in the rear and I noticed a difference......worth the money!
    Crap, should of bought them on line.....that's just me being impatient...again!
  1. Sway Bar Removal
    By Knivx in forum VX Modifications...
    Last Post: 10/07/2012, 06:51 PM
  2. disconnecting sway bar
    Last Post: 04/21/2008, 04:26 PM
  3. Sway Bars
    Last Post: 01/28/2005, 12:07 PM
  4. sway bar question
    By dstruction in forum VX Troubleshooting...
    Last Post: 06/25/2004, 11:00 PM
  5. Sway Bar Diameter
    By jbregar in forum VX Talk...
    Last Post: 10/20/2003, 09:32 PM
