View Poll Results: If proven not too costly, would you make your VX convertible?
Voters
198. You may not vote on this poll
  • Hell yeah!
    50 25.25%
  • Hmm, that's an idea.
    19 9.60%
  • It depends on how the first one comes out.
    28 14.14%
  • Are you out of your Vulcan mind?
    101 51.01%
Results 31 to 45 of 76
Thread: The ultimate Mod!
    Aug 2003
    1999,Silver,Vehicross,0928
    i believe the rx8 is built to be a convertible....they then made it a hardtop.....
    but anyways back to the topic....if u ahve the money anything is possible....just build the vx from scratch to be a convert.....then bolt on the fenders, cladding, hood, etc.....
    ________
    Velvettouch
    Yes ASC does a lot of chops, many for custom one-off vehicle conversions (such as for the VX)- but you are telling us that major auto manufacturers ship ALL thousands and thousands of their vehicles( sold as convertibles) over to ASC and then they are shipped back? ASC is going to go in, add major structural support (that would be much easier and safer to do when designing and building them in the first place) in a production style line? They must have the largest line in the world and lots of robots with only 1,100 employees!
    But look at thier home page - the first statement: " ASC exists to help automakers design, engineer and maunufacture high-imagelow-volume vehicles". That is NOT the same as prodtion quantities.
    The 350Z, Bug, Mustang, PT Cruiser, Porsche, SABB, Lexus convertibles and most all others ARE built as convertibles ON the production line from a design based on the original hard top versions. There is NO ASC sticker/plate on the vast majority of convertibles (and not on any of the factory convertibles I saw @ SEMA, Ford included). But I would be interesed in seeing YOUR Trooper chopped. With money, most anything is possible!
    2001,Ebony, 0486
    I say chop that puppy up. I've seen VXs that cost like $7000. Buy one of those and chop off the top. If it doesnt look good, oh well! Atleast it will be unique. I pledge $500 towards this project!!!
    97 Red VX 0673
    Tone,
    I don't think Nate implied every chopped car came through ASC however I can say that every VW Golf is chopped post production and done by Kharman, incedently Kharman also did a not to good 4X4 version of the Golf.
    Anyhow as I said I do not intend just to hack the top off, my approach will be properly engineered as I intend to seriously offroad my VX but as we say over here "the proof will be in the pudding"
    Col
    Jan 2004
    2000 Black Trooper 3248
    Tone, I will try to get some hard numbers on this.
    By the way, cars are not assembled by robots, only the welds in the bodies are. Painting is done either way, depending upon the line. The dashboards, seats, panels, engines, are all dropped in by hand. An assist device is used on the line so the worker's hand only guides the part, not so much lifts the part into place.
    When I watched Grand Am's being built in Lansing in 1991, I saw two guys putting "IP's" as the tour guide called them (instrument panels) into cars. They had to lift the panels in sequence (they had a series of grunts and noises they used to stay in sync) and then used makita cordless screwdrivers to drive the screws home.
    I was a little surprised, to say the least. I would have envisioned a machine with a scredriver bit at each precise location, and a jig for the dashboard, but muscle and sweat gets the car assembled.
    As far as convertibles go, nothing has to be engineered in the shop, likely a template for cutting and welding, all parts ready to go in. I'm speculating 3 or 4 guys can do one (factory style) in a day. Imagine how many can be done by several hundred workers in a year. You are forgetting too that UAW contracts probably mean the guys actually doing the chops may even work for their respective auto company.
    See here:
    http://www.conceptcarz.com/folder/ve...vehicleTypeID=
    A quote from the article:
    "The all-new Camry Solara convertible will be a joint venture between Toyota Motor Manufacturing, Canada (TMMC) and ASC, which is opening a production facility near the Toyota plant in Cambridge, Ontario."
    "The Solara convertible will be built in a dual-stage process. A coupe body shell will be built at TMMC, then trucked to the nearby ASC facility. ASC will remove the top and perform convertible-specific structural reinforcement. The body then will be trucked back to TMMC where it goes through the entire paint process and is fitted with running gear and interior. The car returns to ASC for final detail work including interior trim, quarter windows and convertible top installation."
    This article is on the older solara, the new one is radical because it is designed to be chopped with no painting afterword.
    Here's a little on the 80's Mustang:
    http://applications.edmunds.com/revi...0/article.html
    A quote:
    "... the Mustang convertible returned in the form of a conversion performed by ASC, Inc. on coupe bodies."
    Here's a picture of the ASC decal I mentioned, at a Mustang parts site:
    http://www.mustangparts.com/images/ascdecal1.jpg
    From an ASC Press Release:
    "Once just a sunroof maker, ASC's award-winning programs include vehicle development and sub-assembly of the Chevrolet SSR; convertible systems for the BMW Z4, Toyota Camry Solara and Mitsubishi Eclipse Spyder."
    Nate
    Jan 2004
    From ASC's website:
    1991: "ASC builds 100,000th GM Cavalier and Sunbird Convertible"
    1989
    ASC introduces first production convertible pickup truck, the Dodge Dakota Convertible
    2000
    ASC opens Munich, Germany technical center for European open-air development
    By the way, they define low volume as capping around 40,000 vehicles per year (per model). I doubt there is a convertible maker out there who isn't capped around there somewhere.
    Nate
    That pic makes me think of my old Amigo!
    Knowledge is power!
    2000, Yellow, VehiCROSS 0602
    Pimp my ride with GAS on MTV
    Ok....so I'm bringing this forum back. I finally moved to LA and spoke with Z from MTV's Pimp My Ride. They saw all the pictures of the VXO2 that I had and they said they could totally make one from my VX. Cost? Hold on....$102,000!!! I got it down to $82k! Hmm...is it worth it? It would be a full time convertible with no working top. Fiberglass with powered opening to reveal a very nice sound system. They would lower the VX by 1" and add 22" rims, Dual exhaust system, totally re-inforced cross bracing, new interior and seats, raked window and eliminate A & B pillar from the door (slick how they showed me it could be done), no more window though cuz they'd have to do something else to make it stop rolling up. I'd still need to get the skid plates from one of you guys though. and paint of any color that I choose. I guess it would be a little less if i didn't do up the sound as nice or kept the factory rims/tire, or kept the same color as the VX I got. I was going to buy a used VX for $6k. 2 concerns. $$$$....and if the VX I get will be ok to handle these mods since I don't know the history. I'm asking if we could document it and make it part of the Pimp my Ride show. That's open for discussion. So....who's got the money? Would you do it?
    '99 Ebony VX #0038
    LOL If I had $100k right now the last thing I would do is mutilate my VX trying to make it look like a VX02!!
    I've thought about what a show like Pimp My Ride could do to a VX, but much of what would truly be an improvement is beyond the scope of what that show usually does. I'm thinking engine swap, solid axle with custom gear set, 35"+ tires, custom suspension and lift, real skid plates (not fiberglass), etc. etc. PMR could definitely do some great custom paint, wheels, audio/video system, and interior redesign, but leave the exterior design alone!!!
    But that's just my opinion.
    Jan 2007
    *BHC* 1999 Ironman. :D 0454
    dude, don't "PIMP MY RIDE", all they do is distroy cars and they fall apart in a year. total waist of money, if you want your VX done right, go to foose, he will make sure your VX will turn out to be better and look like how it's suppost to be, not a bling, sparkaling made with duck tape POS, sorry, thats what i think MTV have done. Good luck though. Hate to see another VX go to the ****'s.
    Turning My VX Into Rally VX
    Points taken. What's Foose? Gotta admit though, if I was a multi-millionaire, I'd go through with the mod. THey know I'm a mechanical engineer with a PE (Professional Engineering) license so we talked a long time about the things they'd have to do to give it more support and still be a performance vehicle. THey estimated 800 hrs on just the top removal, structural support, design...etc. The other stuff was minimal. Oh wells, was fun dreaming for the moment.
    Quote Originally Posted by Baldwin View Post
    What's Foose?
    Foose is the Gold Standard...the MAN.
    Try a Foose Google search...it'll blow yer mind!
    Sep 2004
    1999, Astral Silver, VX, 0938
    Points taken. What's Foose?.
    Wants to drop 80k on an automotive upgrade and hasn't heard of Chip Foose??
    97 Jap Import, Black BEAST
    I don't work in a hair dressers therefore i think i'll keep my roof thanks !!!!!
    Aug 2009
    2000, white
    OK, seriously, I'll do it for 75 maybe 70 grand, and I'll need it for about 10 months. But I guarantee I can get it exactly like the VX O2.
  1. the ultimate gas saver...
    Last Post: 10/14/2008, 08:18 PM
  2. Ultimate hose fix?
    By thedutchguy in forum VX Modifications...
    Last Post: 06/30/2007, 01:44 AM
  3. This could be the ultimate cop car
    Last Post: 02/24/2006, 07:33 PM
  4. Ultimate VX Accessory!
    Last Post: 01/17/2005, 05:42 PM
  5. Ultimate Summer Vx!!!!
    Last Post: 05/01/2004, 06:15 PM
