Getting ready to install the rear door popper; and have a couple of questions for those who have already done it. Apparently from what I have read in some threads from last year, if you wire it so that the popper is activated by the second press of the keyless remote, (the first press unlocking BOTH side doors) then the unlock switch in either door will not only unlock both side doors but also open the rear hatch, right? This means that if you want to unlock one or both side doors without opening the rear you have to manually pull up on the lock stem(s). With this type of setup is there then any reason to install the dash switch? I guess you could simply use the unlock power switch in either door to open the hatch. Any comments, ideas, suggestions would be appreciated. Thanks.
