Results 1 to 8 of 8
Thread: !#@*! Check engine light
Threaded View
  1. #8
    2000 Dragon Green VX 0485
    Quote Originally Posted by Ron Pfeiffer
    Arrghhh!
    Check engine light came on again. Third time in six weeks, and as before, it is the P1441 code. I know its the evap/recirculation system, and I know for sure that it wasn't a loose gas cap. Anybody have any bright ideas about what parts I should look at next, or how I should troubleshoot?
    All three times, it has happened at the same place under the same conditions. It kicks on at the end of a downhill, which I take in 2nd gear. I shift up to drive, make a sharp left, and BAM, light goes on. All three time on a day of average temp and humidity. Code P1441 all three times.
    Any pointers would be greatly appreciated.
    Ron
    In the kick panel fuse box check the 10 amp fuse C3- This energizes both the Canister & Purge solenoids.If that is OK ck for vacumn leaks at cannister.Check for clogged,kinks or pinched hoses at the Evap sys rubber hose line. Ck the filter in air separator which is located near the vent solenoid valve.
  1. first check engine light
    Last Post: 04/26/2010, 07:36 AM
  2. Check Engine Light
    Last Post: 11/01/2007, 05:57 PM
  3. Check Engine Light
    Last Post: 10/29/2007, 01:25 PM
  4. Check Engine Light...
    Last Post: 12/11/2003, 02:45 PM
    Last Post: 06/28/2003, 10:52 AM
