Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
Thread: Speedometer recalibration: is it possible?
Grant Eaton Speedometer recalibration: is... 06/06/2003, 04:41 PM
AlaskaVX Why would you want to do a... 06/06/2003, 04:47 PM
coachreed I considered asking the same... 06/06/2003, 06:50 PM
Grant Eaton I have this thing about... 06/06/2003, 07:45 PM
WyrreJ I think you can buy a box... 06/06/2003, 07:46 PM
Heraclid Also, about the 8% off...... 06/06/2003, 08:27 PM
Tone Autotrans offer a... 06/06/2003, 09:04 PM
Swordy If you want to do the job... 06/06/2003, 09:09 PM
Grant Eaton I ended up buying a set of... 06/07/2003, 12:01 AM
Grant Eaton http://www.autotransinc.com/re... 06/07/2003, 12:15 AM
Tone I�ll try to nail something... 06/07/2003, 05:44 AM
johnnyapollo A good GPS will give you... 06/07/2003, 06:29 AM
coachreed Yeah, I know radar has been... 06/07/2003, 08:16 AM
IsuZOOM Our site owner might take... 06/07/2003, 08:30 AM
Moncha Because of discrepancies, our... 06/07/2003, 08:38 AM
WyrreJ Diameter and circumference... 06/07/2003, 08:53 AM
Moncha Remember to use the good ol'... 06/07/2003, 09:03 AM
Grant Eaton You're right. Let's see,... 06/07/2003, 09:44 AM
mrtew Another thing that no one has... 06/07/2003, 10:35 PM
paultvx I can see how it can be a big... 06/08/2003, 12:45 AM
WyrreJ Am I invisible in this thread... 06/08/2003, 02:38 AM
paultvx Did someone say something? :D 06/08/2003, 02:57 AM
AnalogVX You guys are putting WAY too... 06/08/2003, 01:43 PM
sveltax Isn't one other issue the... 06/10/2003, 01:25 PM
paultvx The dealer doesn't care. In... 06/10/2003, 01:44 PM
mrtew Why the heck would a dealer... 06/10/2003, 07:12 PM
paultvx Some people don't live in... 06/11/2003, 01:27 AM
mrtew Toto, I wasn't saying... 06/11/2003, 04:01 AM
paultvx They get paid when Isuzu OK's... 06/11/2003, 05:44 AM
mrtew Thanks for the thoughtful and... 06/11/2003, 03:51 PM
paultvx The situation may vary from... 06/11/2003, 11:42 PM
WyrreJ Gross yeah, but to net $2K... 06/12/2003, 12:07 AM
paultvx Was just an example. ... 06/12/2003, 02:06 AM
Dallas4u I bet GM and Ford dealers... 06/12/2003, 08:13 AM
WyrreJ I read a little article in... 06/12/2003, 08:33 AM
Tone I�ve got an AutoTrans... 06/12/2003, 10:00 AM
Daver Car & Driver was the magazine... 06/12/2003, 06:51 PM
Clyde Has anyone done any more... 04/16/2004, 10:28 PM
Maverick 10 mph" tolarance " is pretty... 04/17/2004, 06:31 AM
Tone Grant has been running the... 04/17/2004, 06:35 AM
Clyde Hey Tone, Does the... 04/17/2004, 08:28 AM
Tone Yes, set with dip switches... 04/17/2004, 10:12 AM
psychos2 i have larger tires and the... 04/17/2004, 07:57 PM
Clyde Thanks for sending me... 04/17/2004, 10:21 PM
t2p Clyde: . $100 for an 18"... 04/19/2004, 10:02 AM
    Question Speedometer recalibration: is it possible?
    If I get larger wheels for my VX, can the speedometer be recalibrated fairly easily? Perhaps by the dealer?
    Grant
    2000 Proton Yellow #756
    "THE UFO"
    Seattle, Washington
    Dec 2002
    '01 Ironman
    Why would you want to do a thing like that? I can see doing it if you had smaller tires on there, but with larger tires your actually putting less miles on your car. They do have things that show true speed. Just remember what the differance is to a % eventually you won't even have to think about it you just know that 50 mph = 55mph and 60 =66 or however your size tires work out compared to stock (29" or 29.5"). Point being don't spend money you don't need to.
    Mar 2003
    I considered asking the same question... I found by my speeding ticket that I got on the way to Florida a couple weeks ago that my speedo is about 8% off... that is with my 285/60/18's. Then I thought the same as AlaskaVX... why add more miles on than I need to... I'll get used to the speedo.
    TTYL!
    Coach... aka Randy!
    I have this thing about instruments (and things in general) being precise. It must be the German in me.
    I don't care about mileage; I'll own this truck as long as I'm able to drive.
    Feb 2003
    2001, Black, VX, 0781
    I think you can buy a box that sits in between your speedo and your wheels that will do the conversion for you.
    But, you could also use it as an excuse to get yourself a GPS unit and just use it to tell you what your true mph is. Often speedos are undercalibrated at the factory, but a good GPS will give you a pretty precise number. Or so I have been told.
    May 2003
    '99 Astral #1613
    Also, about the 8% off... radar has been known to clock houses at 12 mph. And I don't mean a mobile home. :-)
    Not saying it was what happened with the ticket you got, but police radar is notoriously inaccurate, depending on various factors.
    '99 Ebony Black VX, 0339
    Autotrans offer a recalibrator and I currently have one for testing - is there sufficient interest for this device? It costs approximately $150 and must be spliced into the harness under the vehicle.
    If you want to do the job right, you change your rear end gears to compensate for the change in torque due to the tire size. On some tranny's there are speedometer gears that you can access from under the car for a quick fix. I don't believe ours have that though. Other than that, it's the black box thing tones talking about.
    Its the thrill of the chase
    I ended up buying a set of Pirelli Scorpion Zeros from www.tirerack.com. I paid about $154 each plus $70 shipping (total cost was about $700).
    I bought the 285/55/R18 size. At 30.34", the diameter of the tire is about 2.5% larger than stock, so the speedometer will be a little off, but not too much.
    The other wide-tire option, 285/50/R18, was about 1.1% smaller than stock at 29.22" diameter. (Stock is 29.57".) I figured I would rather make an extra 2.5% on my business mileage expense reports with the bigger tires. Plus, the 285/55/R18's were $40 cheaper for the set than the 285/50/R18's.
    I don't want to do any cladding trimming and from everything I read, this size tire should fit without rubbing the cladding or anywhere else.
    (I hope.)
    The Web site is here:
    http://www.autotransinc.com/Recal.htm
    Actually, I read up on this and I am a little interested. According to their Web site, the ABS system uses speed calculations to determine proper behavior. Although it isn't mentioned, I imagine the speed calculations also affect airbag deployment parameters. My new tires will alter the VX's speed calculation by 2.5% -- that's probably pretty significant when you're talking about the delicate matrix of conditions required to trigger airbag deployment. I wouldn't want to take a risk with impairing the bag's trigger characteristics.
    So... let me know how your testing goes and I might pick one up from you if they aren't too difficult to install or have an unadvertised trade-off.
    I�ll try to nail something down this week. Actually your speedo is going to UNDER report both distance and speed so you�re actually loosing money on the expense report but the good side is the odo will not age as quickly!
    2001, Proton Yellow, #0580
    A good GPS will give you actual speed, so you could mount one and ignore the speedometer readings. Just another option.
    -- John
    John Eaton
    Original Owner
    2001 Proton Yellow #580
    Atlanta GA
    "Metaphors be with you"
    Mar 2003
    Yeah, I know radar has been known to be inaccurate at times, but the number I got from my ticket pretty much went with my own figures... paceing and timeing mile markers. I had already driven about 400-500 miles that day and figured I was off by around 7%-8%. Then after my ticket was issued, I asked the cop to pace me at 65 (the speed limit) and I was reading 59-60mph. Then later in my trip, I had my friends grandfather pace me on the way back up to GA from FL... and his was reading about the same... so, my conclusion is that I'm off about what I figured... 8% give or take.
    Grant-
    It looks to me like your figuring a percentage error with the diameter, right? You need to do an error calculation with the circumference as this is the actual distance traveled per revolution.
    Don't know if I care to adjust mine though. I'll take every bit of extra warranty I can get. I am currently working on a complete auto-pc system that will include GPS so I'll have an accurate number then...
    TTYL!
    Coach... aka Randy!
    Jun 2003
    No VX anymore
    Our site owner might take issue with that
    I know with my boat, (and many boats) GPS is WAY more accurate than the speedometer in the dash. I imagine the same is true with automobiles. I recall an article in a car magazine a short while back where they compared actual speed (tested with what I think they call a fifth wheel) versus reported speed on the speedometer and every car was off by at least 2 MPH, some as much as 10 at high speeds!
    May 2002
    2000, Proton Yellow, VX, 0584
    Because of discrepancies, our local policy is a 10mph given. Anything over, zero tolerance.
    Scott / moncha.com
  1. Is your speedometer off?
    By ohiovx in forum VX Modifications...
    Last Post: 03/26/2015, 05:19 PM
  2. Speedometer issue
    By hellomoto in forum VX Troubleshooting...
    Last Post: 03/25/2010, 06:49 AM
  3. speedometer not working
    Last Post: 05/07/2009, 08:46 PM
  4. Scangauge recalibration - Tire size increase
    Last Post: 08/07/2008, 08:36 PM
  5. speedometer with km/h readout
    Last Post: 06/21/2004, 06:25 PM
