I read through the ideas that came up when i searched but nothing seemed to work. Heres the problem
I noticed that sometimes when I would get in my VX using the remote keyless entry that it would start beeping. It would be a constint beep not on and off. If I got out shut the door locked and unlocked the door with the keyless remote it would stop. Well this weekend it started making the constint beep as I was turning the key when the VX cranked the noise stopped. I got home went to lock the VX and nothing. I got on here and did a search tried to reprogram the remotes using the little green button under the dash. No luck there. The led indicator will stay on now and the keyless remote does not work. It will neither lock or unlock the doors. Any ideas???
