Hi All, i have read this entire thread looking for more posts innorder to figure out what is happening with these engines. I own two Vehicross both 99’s . The engine in my daily driver i rebuilt personally about three years ago out of a 6VD1 Rodeo block which i turned into a 3.5L by installing a. ew crank and shorter pistons as thats the difference between 3.2 and 3.5 L aside from knock sensor tapped hole location in the top of the block. i have noticed that it does use about a litre of oil every 1000 miles. Running 5w30 full synthetic and high performance oil filter. I had installed a catch can and filter on the pcv line for about a half a year and then removed it because it made no difference. Change oil at 3000 miles but its always fairly clean as i am always adding new. The engine in this vehicross was blown when i got it. Rod failure … number 1 i think.. have to check my pics.
