View Poll Results: what year VX did the engine failure occur?
Voters
127. You may not vote on this poll
  • '99?
    70 55.12%
  • '00?
    21 16.54%
  • '01?
    36 28.35%
Results 1 to 15 of 194
Thread: Engine failure poll?
    Feb 2011
    2000 Dragon #0274
    Quote Originally Posted by mrtew View Post
    Obviously there must be some that didn't get posted here, but a 1% failure rate would be over 600 engines.
    From you, Sry just a little anal about math.
    I'm still sold on buying a VX btw. All cars have some failures, one thing I noticed if it's true, hard to tell from just pics. Does the PCV valve lay on it's side? They need to be straight up to really work right. Also are there really no rocker arms? I'm curious how the cams actuate the valves. And how you adjust the valves. Has anyone just put the 02 oil rings on the 99-01 pistons? This oil usage thing has me curious. Isuzu is know for good quality engines generally.
    Junster If it don't looked fixed.. It ain't fixed.
    Quote Originally Posted by Junster View Post
    No, it's upright.
    '99
    That's correct. We don't need no stinkin' rocker arms!
    Our camshafts are driven by internal idler gears instead of a chain. We also have a spring loaded sub-gear assembly that takes up the back lash in the gears to provide high-precision valve timing and reduced noise. Valve action is controlled through an inverted bucket type tappet that rides against the camshaft lobe.
    Valve adjustment is made by increasing or decreasing the thickness of the shim until the correct amount of valve clearance is obtained.
    This is a very rare Isuzu Tech video I have for adjusting the valves, if ya really wanna see how it's done.
    7:11, 14.1 mb, 320x240, wmv file-
    http://www.drivehq.com/file/df.aspx/publish/mgpa/techvids/valvadj.wmv
    I'm an original owner with 238,000 miles on my engine. The valves have never been adjusted. It purrs like a kitten and runs like a dream, so I never saw a reason to have that done.
    Mark Griffin (a VX lifer)
  1. considering VX, engine failure?
    By atilla_the_fun in forum VX Talk...
    Last Post: 02/24/2010, 10:24 PM
  2. JDMs and engine failure
    By AussieVX in forum Japanese Domestic Model (JDM) VXs
    Last Post: 05/28/2009, 08:16 AM
  3. Those with engine failure
    By Maugan_VX in forum VX Talk...
    Last Post: 08/25/2004, 03:18 PM
  4. Engine Failure Questions
    By t2p in forum VX Troubleshooting...
    Last Post: 03/23/2004, 02:31 PM
  5. Diagnose Engine Failure??
    By VX_PA in forum VX Talk...
    Last Post: 11/19/2003, 08:50 AM
